im new to PC's, a corsair h100i would be enough to cool a 3570k at 4.4-4.5GHz right?
Main Rig
CPU-
AMD FX 8350 | CPU Cooler- CM hyper 212 Evo | GPU- Radeon HD 7970 | RAM- G.SKill Ripjawz X 2x4 | Storage- 1TB WD Black | 128gb Plextor Ms5 | Case- BitFenix Shinobi   | Motherboard- Gigabyte AM3+ UD3 | PSU- Rosewill hive 750 watt
 Media PC
CPU- A10-5800k | GPU- Onboard | RAM- Ripjaws X 4Gb | Storage- Seagate 1TB | Case- Bitfenix Prodigy M | Motherboard- MSI A75M-E35 | PSU- Antec 350W Basiq
https://linustechtips.com/topic/25746-enough-cooling/
yeap, you still need good airflow inside your case, so that you cooler doesn't use overheated air from inside.
aside from that, the h100i can deal with that no problem.
Main rig. Updated :D CPU: FX8350 @stock Cooler: Corsair h110 Motherboard: Ga-990fxa-ud5 Memory: Corsair Vengance 8Gigs 1866Mhz GPU: MSI GTX 970 SLI (blower cooler)  PSU: Cooler Master Silent pro 850w SSD: Corsair Force GT 60Gb HDD: WD 500 Caviar blue Case: Thermaltake core V71 Fan controler: NZXT Sentry
Secondary PC: CPU: i5 4670k @stock Cooler: Thermaltake NIC L/31 Motherboard: Asus Z97I-PLUS Memory: Corsair Vengance 8Gigs 2133Mhz GPU: ZOTAC GTX 780 (Titan cooler) PSU: Antec 520m Pro SSD: Corsair Force GT 60Gb HDD: WD 500 Caviar blue & WD 2TB Green Case: Thermaltake core V1
https://linustechtips.com/topic/25746-enough-cooling/#findComment-326957
Main Rig
CPU-
 Media PC
https://linustechtips.com/topic/25746-enough-cooling/#findComment-327703
Meant to add this to the quote but I'm on mobile and seem to be able to, I'm using non-stock fans on it and adding 3 other fans to the case which should ne enough
Main Rig
CPU-
 Media PC
https://linustechtips.com/topic/25746-enough-cooling/#findComment-327708
It also depends on whether or no you can get there. Whether you get a below-average overclocker or not. My friend's 3770K can't get past 4GHz, even @ 1.3V
AsRock Z77 Extreme4 | Intel Core i5-3570K | 32GB G.SKILL 1600MHz | EVGA SSC GTX 1060 6GB  | Corsair CX-750W | NZXT Tempest 210 | Cooler Master Hyper 212 EVO
https://linustechtips.com/topic/25746-enough-cooling/#findComment-328314
I'm looking at the HAF XB at the moment and there's just 1 120mm fan for intake at the back if I have a h100 (dual 120mm) exhaust at the front of the case .. Think that will be enough?
http://www.coolermaster.com.au/product.php?product_id=6797
I don't really want super grate air intaking from the front
GamingPC: Intel 4770k CPU, 2xMSI 780 GTX Twin Frozr, 16 GB Corsair Vengeance Pro, Swiftech H220 CPU Cooler.
Cookie Cutter Build log
https://linustechtips.com/topic/25746-enough-cooling/#findComment-328602
