How many watts do i need?
Go to solution Solved by wtfxmitchell,
850watt
850watt
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
https://linustechtips.com/topic/256373-how-many-watts-do-i-need/#findComment-3508113
Get a better CPU. Get the 4690k
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/256373-how-many-watts-do-i-need/#findComment-3508118
That might be cutting it a little , especially overclocking , and with high end hardware you might want overhead. HX1000i would be ideal @IKG_Pureeto
Thanks, because the normal power load of the 290x is roughly 300 watts, im not sure if 850, or 1000 watts would sustain an entire system with two power eating monsters...
https://linustechtips.com/topic/256373-how-many-watts-do-i-need/#findComment-3508207
1000watts will be more than enough!
could probably go with 850w, but i would not go lower than that.
CPU: I7 4790K GPU: Manli GTX 980 Mobo: Asus Gryphon z97 RAM: kingston Hyper x fury 16GB 1866mhz PSU: EVGA supernova 750W G2 SSD: Samsung 840 evo 500GB HDD: WD Black 3TB Case: Parvum s2.0 Fans: Noiseblocker E-loop 800rpm Cooling: Custom water cooling
https://linustechtips.com/topic/256373-how-many-watts-do-i-need/#findComment-3508345
Really? 850 watts? even under heavy load? including the entire system?
2x 300watt for gpu's is 600 watts +100 watt for the cpu is 700 and you don't want your psu to run at max capacity when onder load because of the efficiency curve
https://linustechtips.com/topic/256373-how-many-watts-do-i-need/#findComment-3508562
Two R9-290Xs including the rest of the system will pull under 1000W for sure.
Two R9-290X : 675W.
http://www.anandtech.com/bench/product/1075
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/256373-how-many-watts-do-i-need/#findComment-3508610
Two R9-290X : 675W.
i've never said it will pull more than 1000 watts xD
you also need to include fans, harddrives, usb devices, those things can add up fast and if he's planning to overclock you get reach the 750 watts with no problems and as i said, you don't want to have a 750 watt psu if you can pull 750 watts that's why i recommend a 850 watt psu
https://linustechtips.com/topic/256373-how-many-watts-do-i-need/#findComment-3508628
Review from Toms's Hardware. TWO R9-295X2 (4 GPUs in total) on a 1000W PSU.
http://www.tomshardware.com/reviews/amd-r9-295x2-1000w-psu,3907.html
But yes, I agree with you, 850W would be the ideal rating.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/256373-how-many-watts-do-i-need/#findComment-3508654
Hawaii pulled close, and in some cases over, to 400W - both in synthetic and gaming loads - on the Anandtech review. It'll be slightly different with XF but not too far off if you push your limits. 850W is skimming the surface to me; I've only recommended/debated 1000W+ 80+ Gold power supplies or better when 2x 290X were involved.
Edit: I wanted to mention the 295X2 but this guy already did:
Way surprising that they didn't blow their shit up, but like they said it's all about what you're using. And 290X crossfired aren't quite the same as a 295X2. Still, great post. I just know that nuclear meltdown in an expensive rig can be that much closer (too close for me) when you start tossing these fuckers into multiple PCI-E slots.
https://linustechtips.com/topic/256373-how-many-watts-do-i-need/#findComment-3508753
I have an r9 280x and an i5 non-k 2500 at 3.8ghz, system draws less than 400 watts simultaniously running furmark and prime95. Yes I understand that these are potentially damaging stress tests. I ran them for 30 seconds.
https://linustechtips.com/topic/256373-how-many-watts-do-i-need/#findComment-3514474
