System Lag
Go to solution Solved by Timmy-P,
Did you uninstall your NVIDIA drivers?
Hi guys,
I recently changed my graphic card from gt9600 to R7 260 2GB. After changing my card, I experience some lag in my system. Is that because of the graphic card or something else. My system config is core 2 duo, 4gb DDR2 ram, 500gb HD. My board has PCIe 2.0 slot. Pls need your help in this. Thanks in advance..
https://linustechtips.com/topic/256304-system-lag/
What kind of lag?
https://linustechtips.com/topic/256304-system-lag/#findComment-3507217
