Laptops not on 802.11n frequency and not on 5GHZ band
Solved by ionbasa,
There are definitely older devices that use wireless G in my household. I can't set my router into N only mode, there's no option. I have the Netgear C3700.
Those older devices are what is causing your links speeds to drop.
My suggestion:
Go look for a cheap B/G access point, maybe find one at a garage sale, and setup a separate wireless network for Wireless G devices, and use your c3700 for wireless N compatible devices.
