So here's the deal. Im under tight budget approx. 1,400$
So can you guys like. Give me a list with the parts that i really want?
Unsure whether 5820k or 4790k?
Single Gtx 980 (cheapest best performance)
Mobo with wifi and bluetooth.
About 16 gigs of ram to start off with.
And 120 kingston ssd which is also about 75$ here
Factor in the nzxt 410 case about 100$ here
Also im from the philippines and the parts here have additional costs for aome odd reason.
https://linustechtips.com/topic/255869-help-with-my-build/
You can't do this for 1400
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/255869-help-with-my-build/#findComment-3502273
no chance bro.... the GTX 980 alone will already be half of your budget here in the Philippines
edit: just checked, well, maybe not half the budget but near enough. you can PM me and i can help you with the build. where are you planning to buy your parts?
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
https://linustechtips.com/topic/255869-help-with-my-build/#findComment-3502278
I'd get the MX100 128GB SSD because the Kingston SSD has been getting alot of bad reviews of it being borderline rubbish.
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
https://linustechtips.com/topic/255869-help-with-my-build/#findComment-3502770
i am thinking about the gtx 970. but can someone persuade my why it's better? after a little while maybe he 980 might show better performance? i've watched a lot of review but that 10% performance difference might be a big difference in the future. or maybe not?
https://linustechtips.com/topic/255869-help-with-my-build/#findComment-3502940
also if someone from the philippines is reading this. can you refer me to a cheap place i can buy from?
I assume you didn't read my comment? I'm from the Philippines. Also, PChub is a good place to by parts from. I bought my PC there.
https://linustechtips.com/topic/255869-help-with-my-build/#findComment-3504843
where is it located? and is it better than dynaquest pc? i keep seeing ads from olx. and it seems to me that they are actually selling a little bit cheaper than in malls/
https://linustechtips.com/topic/255869-help-with-my-build/#findComment-3505486
maybe gilmore? but i've been checking olx and as i mentioned above dynaquestpc "seems" to be selling a bit cheaper?
https://linustechtips.com/topic/255869-help-with-my-build/#findComment-3505495
you can quote more then one person in one quote.
that motherboard is ehhh. + it doesnt have wifi that you wanted. I would recommend upgrading the motherboard if you even want to overclock at all.
http://en.wikipedia.org/wiki/LGA_1150 difference in chipset. that motherboard has a h81 chipset.
https://linustechtips.com/topic/255869-help-with-my-build/#findComment-3506037
i was planning with maybe going with the VII formula. or maybe VI? but then i considered getting the asus z97- pro (wifi). which is better?
https://linustechtips.com/topic/255869-help-with-my-build/#findComment-3507448
@ProjextX01 I would go with only 8 gb ram and add later some if you need to and take a ~100$ mobo + a pci wifi card for around 10 dollar
i'd like to have 16g's from the start. but mobo/ do you any recommendations? any better one's with better performance?
https://linustechtips.com/topic/255869-help-with-my-build/#findComment-3508717
http://www.tipidpc.com/useritems.php?username=PCHub
http://www.tipidpc.com/useritems.php?username=dynaquestpc
what is your budget in pesos?
btw i recommend a Palit card because they are cheaper and they perform great.
https://linustechtips.com/topic/255869-help-with-my-build/#findComment-3509090
i actually have been checking their posts hahaha. and in Php. about 60k i can maybe shell out a bit more if it's realllyyy worth it.
https://linustechtips.com/topic/255869-help-with-my-build/#findComment-3509354
i forgot to mention. but is palit really that good? i've been watching reviews but it feels like the video card itself will feel a bit cheaply made?
I use a palit card myself and it's working great. I think they are cheaper because other brands have more expensive shipping. Palit sells mainly in Asia so it would make sense that they have lower shipping cost here.
https://linustechtips.com/topic/255869-help-with-my-build/#findComment-3509814
