ram help
Go to solution Solved by LemonSpice,
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) Desktop Memory Model F3-17000CL9D-8GBXM
  • DDR3 2133 (PC3 17000)
  • Timing 9-11-10-28
  • Cas Latency 9
  • Voltage 1.65V
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) Desktop Memory Model F3-2133C10D-8GXM
  • Timing 10-12-12-31
  • Cas Latency 10
  • Voltage 1.6V
help guys! one on top cost more by like $10 but cas is lower,timing is more tight. however voltage is more up. would there be much difference for the $10 for the top one? also would i need to oc my cpu a little for this to achieve 2133?
high speed ram makes very little difference you will be fine either way
  • Timing 9-11-10-28
  • Cas Latency 9
  • Voltage 1.65V
  • Cas Latency 10
  • Voltage 1.6V
https://linustechtips.com/topic/255401-ram-help/
  • Timing 9-11-10-28
  • Cas Latency 9
  • Voltage 1.65V
  • Cas Latency 10
  • Voltage 1.6V
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/255401-ram-help/#findComment-3497237
  • Timing 9-11-10-28
  • Cas Latency 9
  • Voltage 1.65V
  • Cas Latency 10
  • Voltage 1.6V
and no you do not need to oc your cpu as that might actually o the opposite
https://linustechtips.com/topic/255401-ram-help/#findComment-3497238
@Rheinwasser
@JEman99
even if ram has higher voltage than standard 1.5v? so getting the cheaper one won't do me any bad.
no 1 cas will not do really all that much
https://linustechtips.com/topic/255401-ram-help/#findComment-3497268
