How da heck do i fix dis
Lays
http://store.steampowered.com/app/6060/?snr=1_7_15__13
I have win7 and so does my buddy
It says windows xp/2000/vista, friend said he plays it but the sound doesn't work sometimes, is there a fix for that?
Have you tried running it in compatability mode?
Is this the real life? Or is this just fantasy?
Try running it in compatibility mode.
how I do dat? I'm retarded XD
go to your folder ex: Steam\steamapps\common\Star Wars Battlefront II\GameData
there you will find the starwars battlefront file, right click, 2nd tab on the left is compatibility.
I tried running mine on XP service pack 2, but it only got me to menu sadly :(
hope u got a better luck on this, it's a good game
Check out the build: Used to be Obot, now Lilith
Shameless: Me
Where are your games stored? Also, I've played that game on my W7 computer, and it runs fine.
I haven't tried playing it yet my friend said he was having issues with it and i was going to buy it and play with him
As zip said, you'll need to go where ever your games are stored, right click on the exe file for the appropriate game, click on properties, and click the compatibility tab.
I just opened it normally and it's working good so far, gives me an option to play with 7.1 surround in my headphones+ 5760x1080 XDDD
Is your friend's sound configured properly in general?
it works now, i did what you guys told me too works for him now
