Cooler Master Hyper 212 EVO - will it fit ?
Solved by MourningSouls,
There is a good chance the stick closest to the fan will make contact. If you're only using two sticks then you could use the farthest slots provided your motherboard has no issue with this.
Vengeance has a low profile version.
Featured Topics
Worstcaster ·
Posted in Peripherals2 -
4
5
davidholzapfel09 ·
Posted in New Builds and Planning4 -
4
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
