Will my psu be enough
Solved by Aniallation,
Any more inputs from other users? i want to be sure before i make the purchase
Yes. The OCZ ModXStream isn't a great power supply, but I have the 700W version and I am running an overclocked i7 + a 290X off of it with no issue, so you will have no problem running an overclocked newer-generation i5 and a 280X. Even overclocked the most your computer would pull is around 450W, which the 600W MXS is perfectly capable of.
