I'm trying to overclock my G3258 to 3.7GHz to start, and I have the voltage set at exactly 1.000. I applied the voltage, and restarted, then went in to change the multiplier to 37 (for 3.7GHz), and I hit apply and restarted again. And, lo and behold, my CPU is still only at 3.2GHz. What the hell am I doing wrong?
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/253954-overclock-not-applying/
Turn Turbo Core off and any Power saving features off in the BIOS
--- CPU:  AMD A10-7850k --- Motherboard:  ASUS X88MPlus --- RAM:  G-Skill 8GB Ripjaws X DDR3 2133 Dual --- GPU:  Integrated APU --- Case:  Aerocool Dead Silence Gaming Cube Case  ---
https://linustechtips.com/topic/253954-overclock-not-applying/#findComment-3478923
Did you update your bios?
Already has the latest.
Did that first.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/253954-overclock-not-applying/#findComment-3478931
What board do you have? You might wanna try re-flashing the BIOS chip. I had the same issue on my P8 Z77 LE Plus board. Re-flashing the BIOS fixed my issues.
https://linustechtips.com/topic/253954-overclock-not-applying/#findComment-3480721
Gigabyte Z97X-Gaming 5. I mean, in most games it doesn't actually bottleneck it very much (ETS2 runs fine and isn't bottlenecked at all, and Far Cry 3 might be bottlenecked a little), but in Bioshock Infinite it is terrible.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/253954-overclock-not-applying/#findComment-3496966
@tmcclelland455
have you tried using xtu to oc?
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
https://linustechtips.com/topic/253954-overclock-not-applying/#findComment-3497125
@tmcclelland455
Have I what now?
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/253954-overclock-not-applying/#findComment-3500353
@tmcclelland455
have you tried using Intel Extreme Tuning Utility to Overclock???
http://www.intel.com/content/www/us/en/motherboards/desktop-motherboards/desktop-boards-software-extreme-tuning-utility.html
use xtu to OC in windows.
just restart the system to see if the settings apply.
do your voltages change when you do it in the bios?
https://linustechtips.com/topic/253954-overclock-not-applying/#findComment-3500762
@tmcclelland455
I did yesterday, and nothing happened.
its not gonna overclock untill you apply some load
thats how turbo works
Um... Turbo only works on CPU's that support it, and it only boosts the core speeds up when temperatures and load both agree...
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/253954-overclock-not-applying/#findComment-3513484
make sure you don't have speedstep enabled, that messed things up for me.
Think that's off too.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/253954-overclock-not-applying/#findComment-3514338
well, di you try applying settings multiple times, sometimes I had to apply settings, reboot, apply settings again and it worked xD
Recovering Apple addict
ASUS Zephyrus G14 2022
CPU: AMD Ryzen 9 6900HS GPU: AMD r680M / RX 6700S RAM: 16GB DDR5
https://linustechtips.com/topic/253954-overclock-not-applying/#findComment-3517942
Did that for close to an hour.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/253954-overclock-not-applying/#findComment-3518141
