I am currently rendering in Adobe Media Encoder and I'm hitting temps around 90-92 degrees centigrade. I've set the affinity core count to just 2, out of 8 and still I hit 90 degrees, how do I slowly render to reduce heat output?
Thanks.
Intel i7 4790k / MSI Z97M / Hyper 212 Evo / MSI Twin Frozr GTX 770 / 16GB Corsair Vengeance 1600MHz / Fractal Design Arc Mini R2 / Corsair CS750M / Samsung 840 Evo 250gb SSD /  WD Blue 1TB
https://linustechtips.com/topic/253371-how-to-reduce-cpu-usage-on-specific-programs/
task manager, set program to which priority
What if there are no other tasks going on besides the render?
you can set it to lower than average priority....
I've done that and it still uses around 100 percent.
Probably needs some time to adjust to which percent/priority
Hmmmm, how long would it take? I'm a bit worried about leaving this render at 90C and don't want to for much longer. It doesn't look like the load % is dropping at all.
What the hell did you do overclock it on a stock cooler? Was getting like 70C with stock cooler stock clock with i7 4770k
Nope, just 100% load that's all.
I re: my original post, it would still stay at 100 percent, it's just controls which one should get the most priority.
You can underclock your CPU but that would affect all programs.
Best solution is to replace thermal paste or buy a new cooler.
Thanks.
Dialling down that isn't really a permanent solution. if it's happening in that application, then it will happen somewhere else. Best to figure out a hardware solution to your cooling issues.
CPU: Intel I5-4690k (stock) Motherboard: Asus B85 Pro gamer RAM: 2x4 - GB Avexir kit (xmp is not enabled) GPU: XFX R9 280X DD Case: Coolermaster Storm Enforcer Storage: Samsung 850 EVO 250GB, Seagate Barracuda 1TB, WD 250GB PSU: Thermaltake Smartpower 750w Monitor: BenQ RL2455HM Cooling: 200mm front intake, 200mm top exhaust, 200mm rear exhaust Keyboard: Corsair Vengeance K70 Mouse: Logitech G502 Proteus Core Sound: Kingston HyperX Clouds and Logitech Speakers Operating System: Windows 10 64bit
