XFX double D R9 270X hits 90 degrees C
Solved by typographie,
ok, but why u do dis furmark?
Furmark is a torture test. It's doing exactly what it's designed to do. If you want to expose an unstable overclock, you want to use a worst-case scenario workload. Unigine is a great benchmarking application—but it behaves like a game does, just a very consistent game. It doesn't exert the same pressure that a real stress test does and it may not expose instability like Furmark does.
Even the most intensive games won't sit consistently at 100% forever so you won't see the same temperatures you see in Furmark. The GPU load will fluctuate when the bottleneck shifts to something else for a moment, or when you need to load a new map, or whatever.
