One Build - Two Questions
Hi there, for some reason i didn't get emails about your posts, so i didn't notice.
I was trying to give people an idea of my skill level, so that they wouldn't need to try to dumn thing down
It just seems to me that the power throughput of a 6+2 ping plugging to a 8+6 pin doesn't work, that's just my reasoning, but it's probably incorrect, which is why i turned to the LTT forums, because the people here are great.
I haven't found anything in my research. I was hoping someone else would have a 780 (not much to ask for)
I'm afraid you didn't read my post. the PSU has a 6+2 pin, and the adaptor is supposed to end with an 8+6 into the GPU, that's all i know.
I'm buying for the 780 for 250AUD from someone i know. A lot cheaper than a 970.
I did read it but i didn't quite understand it then. Or i still don't understand it (?)
You need to hook up two seperate cables to the GPU, you can't split one 6+2 pin cable with an adapter. Too much current going through one cable.
If you're having too few PCIe power cables you can just use a molex to 6 pin adapter on a seperate molex-harness.
