Hello guys, Im new to the forums so please excuse me..
I just wanted some input on thermal paste on the Intel 4790k processor.
Here's what I will be using:
Asus Sabertooth Mark 2
Intel 4790k
Corsair h100i
And yes, I plan on overclocking
If you guys have some picture references or tips for me, that would be great. Thanks!
https://linustechtips.com/topic/251354-4790k-thermal-paste-help/
The cooler should come with some. If you'd rather use something else other than what comes with it, try Noctua's NT-H1. It's what I use. :)
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
https://linustechtips.com/topic/251354-4790k-thermal-paste-help/#findComment-3445065
@ClassyEnd
Hello and welcome to the forum. Please remember to follow your topics and quote or "@" someone to let them know you have replied.
The H100i comes pre-applied with thermal paste, so you won't have to worry about doing it yourself. If you do want to buy some performance thermal paste, I highly recommend Gelid-GC Extreme, Prolimatech PK-1, Noctua NT-H1, Arctic MX-4, and IC Diamond 7. They will also work well on your GPU shaving off an additional 2-4C.
If you do want to buy and apply your own, you will first need to clean off the included thermal paste. To do so, use 90% or greater Isopropyl Alcohol along with microfiber cloth or coffee filters. I recommend having toothpicks nearby in case any accidentally gets in some hard to reach crevices.
To apply your own thermal paste you can use one of two methods. The pea method or the spread method. The pea method is placing a small pea sized drop on the center of the IHS and letting the mounting pressure of the cooler spread it out for you. The spread method is similar, except you spread the paste out yourself using a business card or some other spreading utensil. With high end thermal pastes, it is typically very viscous, so it is recommended to heat the syringe up by placing it in a plastic bag and boiling it for a few minutes. This makes the paste much more loose and easier to work with.
Lastly, the H100i is known to have mounting problems and is not guaranteed to work for everyone out of the box. Sometimes a washer mod is necessary in order for the cooler to make proper contact. Im on my phone otherwise I would link you the washer mod guide. It is easy to find though, just type in H100i Washer Mod into google and it will pop up.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/251354-4790k-thermal-paste-help/#findComment-3445844
@Faceman I'm planning on using the Asus Sabertooth Mark 2, so I've never heard of people having mounting issues with it, unless I haven't looked hard enough.
people seem to have mounting issues with a wide variety of motherboards. There doesn't seem to be a consensus of which mobo work and which don't.
https://linustechtips.com/topic/251354-4790k-thermal-paste-help/#findComment-3452674
