Im changing my psu because sometimes my computer is dying by itself sometimes it happens around twice a month. I really think its because of my PSU(TT 650w) cant keep up with my GPU(shappire dual-x R9 280x) it says it needs 750w to power. I really need to change it but im not sure what to get since im dont know enough things about PSU.
Thinking of getting:
Corsair RM series RM850 80+ Gold fully modular PSU
Any recommendations?
Thank you :)
My Rig:
CPU: AMD FX-6300 3.5Ghz Black Edition
MOTHERBOARD: Gigabyte 970A-DS3P
RAM: G.Skill RipJawsX 8GB Dual 1600 CL9
GPU: Sapphire R9-280X Dual-X OC 3GB GDDR5 384bit
CASE: Aero Cool Xpredator X1 (Black)
STORAGE: Seagate 1TB 7200RPM 64MD Sata Hard Drive 3.5"
PSU: Thermaltake Toughpower Grand 650W
DISPLAY(S): Samsung 22" LED S22D300
COOLING: Cooler Master Hyper T4
KEYBOARD: Corsair Vengeance K70 RGB
MOUSE: Razer Naga Epic
SOUND: Razer Kraken 7.1
OS: Windows 8.1 SL
https://linustechtips.com/topic/249253-changing-my-power-supply-help/
The psu recommendation on the graphics cards' website are highly inflated in case you're using a crap psu. The 280x easily runs off of a decent 550w. Your current psu is more than enough.
If your psu is causing the issue, it wouldn't be because it wasn't big enough.
Please, with an R9 280x your entire system uses only 350W under load so it's definitely not your PSU
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
Any suggestions on how to do that?
well i would run prime95 + furmark at the same time. this is way more load than a game can do . so if the pc shuts down run the tests individually and see which cause the problem. if nothing happens run memtest
I ran furmark as furmark and prime95 at the same time about 30mins computer didint crash or shut down. Then i ran furmark for 1hr35mins and nothing happened it was totally stable. My rig seems to be doing pretty well :/ I dont know whats the main cause of this pc just dying out on occasions. Thanks for the help tho :)
wow thats a long furmark test.stop with 30min runs couse it really stresses the card. ok its definitely not the psu the load is way more than a game can do. its not the hardware either thats for sure
oh crap i didnt know that 30mins would be fine lol but yea at least i know its not about my hardware.
I think it could be the power suppily. I like both corsair and if you can pay the price some of the best are made by seasonic.
Me too i really think its my psu sometimes its failing. when my computer dies out it will take me around 3-5mins before i switch on my PSU or my computer wont boot up
Forgot to add some novatechs power supplys are good as some are built of seasonics hw.
