Ya that should be enough power. Keep in mind going crossfire or SLI might require a bit more power.
Me: Yeah I just really can't get my H220 working again, I've tried everything that was suggested in the forum.
Brian (Swiftech Support): Hmm, have you tried slapping it?
https://linustechtips.com/topic/24888-do-i-have-enough-power/#findComment-315237
Yep! It should be more than enough.
If you want to be sure, use eXtreme Power Supply Calculator to calculate everything that your build will have.
Though I would recommend going with a different PSU.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/24888-do-i-have-enough-power/#findComment-315245
Yes, a good 500 Watt supply (80plus bronze+) can drive just about any PC with a single graphicscard.
Christopher Kruse | Webdeveloper (Interface & Applications)
i7 3770k (3233C Batch) @ 4.2ghz | Asus P8Z77 WS | Gigabyte 780 Ti OC  | Corsair Vengeance LP 1600 32GB DDR3 | Samsung 850 EVO 500GB +2x Samsung 840 EVO 250GB + Samsung 830 256GB + 4x WD30EFRX, 2x WD30EZRX, 1xWD20EARS | Corsair AX750 + Bitfenix Extensions | Fractal Design Define XL R2 + Xigmatec 3in3 Hotswap Cage | Noctua NH-D15 + Thermal Grizzly Kryonaut, 5x Noctua NF-P14s redux-1500 PWM | Peripherals: Logitech G502 + Corsair K70 RGB + Red 40A-L O-Rings | Sound: Denon AVR 2807 via HDMI + 2x Nubert nuPro A-20 + 1x B&W CC6 Center | SoundMagic E10 | Jabra Speak 410
https://linustechtips.com/topic/24888-do-i-have-enough-power/#findComment-315246
What size would be good for a crossfire config?
650 watts.
https://linustechtips.com/topic/24888-do-i-have-enough-power/#findComment-315264
650W if it's something like dual 650 Ti Boosts; higher end cards, 750W, or even 850W for dual titans or 780's or something like that.
https://linustechtips.com/topic/24888-do-i-have-enough-power/#findComment-315410
none of those cards are capable of cross fire, i think you mean SLI :p.
CPU: i5 3570K @4.5GHz    GPU: R9 290   MOBO: ASUS p8z77-v  RAM: 8Gb corsair vengence   CASE: ARC MIDI  PSU: XFX pro 550W  HDD: 2tb segate baracuda
https://linustechtips.com/topic/24888-do-i-have-enough-power/#findComment-315426
Well do you work out?(yea 500wtt should be enough).
Life is pain. Anyone who says any different is either selling something or the government.
----CPU: FX-6300 @ 4.2ghz----COOLER: Hyper 212 EVO----MOBO: MSI 970A-G46----PSU: OCZ 600watt----CASE: Black Corsair C70----GPU: Sapphire 7870 dual fan ghz edtion----2 random HDD'S----A couple fans here and there. Mouse: Gigabyte M6900-------Keyboard: Logitech G105-----Mousepad: Steel series something something.
https://linustechtips.com/topic/24888-do-i-have-enough-power/#findComment-315429
