PC WONT TURN ON. HELP!
Go to solution Solved by Michael Rahmani,
It booted into the Bios and I just rebooted. Everything seems to be working now! Still don't know what the problem was but at least it is working. Thanks everyone!
Hello, my pc wont turn on. the motherboard is on and it lights up but when i press the power button on the case or on the motherboard nothing happens at all. Last time it was on it was when the power went out last week . I didn't turn it on since last week because I didn't have much time to game and since it is saturday today, I wanted to play some games but it wont turn on. Please help!
Thanks!
https://linustechtips.com/topic/247277-pc-wont-turn-on-help/
I would say to make it as barebones as possible and then testing it, slowly adding hardware to find the culprit.
https://linustechtips.com/topic/247277-pc-wont-turn-on-help/#findComment-3392252
is it plugged into the wall son?
He claims LEDs are lit on his motherboard.
https://linustechtips.com/topic/247277-pc-wont-turn-on-help/#findComment-3392262
Try this fix..
Take out your AC Connection (the PSU Cable) out of your PC, after that press on your powering button and then plug the AC back in.
Wait like 3-5 minutes and then power it on.
Security Analyst & Tech Enthusiast
Ask me anything.
https://linustechtips.com/topic/247277-pc-wont-turn-on-help/#findComment-3392306
Didn't work. Thanks for trying, though!
He means unplug the power supply from the wall and hold the power button for a good 20 seconds to drain the power completely. I hope you're not using some no name brand.
Main: i7 2600 | ASUS P8Z68-V | 2x4GB Vengeance 1600 | GTX 580 | WD Blue 1TB | Antec TP-650C | NH U12S | W7 x64
Backup: X6 1090T | MSI K9A2 Platinum | 4x2GB XMS2 800 | GTX 550Ti | WD Blue 1TB |  Antec VP-450 | CM TX3 | W7 x64
https://linustechtips.com/topic/247277-pc-wont-turn-on-help/#findComment-3392358
Sometimes that works, sometimes it doesn't. If it doesn't work its likely that the power outage fried your power supply.
https://linustechtips.com/topic/247277-pc-wont-turn-on-help/#findComment-3392381
Most likely but he could always test it by bridging the green and a ground wire together.
https://linustechtips.com/topic/247277-pc-wont-turn-on-help/#findComment-3392393
Just for statistical reasons, may I ask, how old are you?
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
https://linustechtips.com/topic/247277-pc-wont-turn-on-help/#findComment-3392397
