1. Budget: $500-$600. Location: Ohio, United States
2. Aim:
So, I am planning on building my first mini-itx build, something similar to the size of a console. It will generally be used as an HTPC, but I still plan on it packing a decent punch in medium game settings. I wanted to keep power consumption as low as I could, while maintaining a decent amount of power behind the hardware. OCing will not be a priority, though if I find myself within a decent area in temps, I will consider doing so.
Here is what I've come up with so far:
http://pcpartpicker.com/p/NdzZGX
My concerns are mostly with bottlenecks. I have not made an Intel build in over 12 years, and I have hardly kept up with the Intel side of things (my main box is a cheap 8320 build). As far as performance goes, the GTX 750 TI will hit exactly where I need it to hit for 1080p gaming, and will also use very little power (60w TDP). The Intel CPU should also be fine with a stock heatsink, due to its low TDP as well.
3. Monitors:
Most likely a 1080p HDTV, or a single 1080p computer monitor depending on scenario.
4. Peripherals:
None required, got my own copy of windows 8.1
If anyone could point out any potential bottlenecks with this setup, or offer any better suggestions within the same general price range, I would appreciate it.
-MageTank
My (incomplete) memory overclocking guide:
Does memory speed impact gaming performance? Click here to find out!
On 1/2/2017 at 9:32 PM, MageTank said:
Sometimes, we all need a little inspiration.
https://linustechtips.com/topic/246604-mini-itx-build-bottleneck-concerns/
Better PSU (more reliable) and that chipset will limit your overclocks. You're better off with a Z87 or Z97.
Try this:
http://pcpartpicker.com/p/NsgP99
My rig: Intel Core i7-8700K OC 4.8 | NZXT Kraken X62 | ASUS Z370-F | 16 GB Trident Z RGB 3000 (2x8) | EVGA 1070 SC | EVGA SuperNova NEX650G1 | NZXT H700 | Samsung 250GB 850-EVO | 2x 2TB Seagate Barracuda HDDs
Here is a more kick-ass version:
Motherboard: ASRock H81M-ITX Mini ITX LGA1150 Motherboard  ($64.98 @ SuperBiiz)
Storage: A-Data Premier SP610 128GB 2.5" Solid State Drive  ($59.99 @ NCIX US)
Video Card: PowerColor Radeon R9 270 2GB TurboDuo Video Card  ($129.99 @ Newegg)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($29.99 @ Amazon)
Total: $515.95
Generated by PCPartPicker 2014-11-07 20:50 EST-0500
This is even more Kick-Ass:
Video Card: Club 3D Radeon R9 270X 2GB '14Series Video Card  ($154.99 @ NCIX US)
Total: $620.94
Generated by PCPartPicker 2014-11-07 20:54 EST-0500
Pretty fast responses, awesome. The motherboard platform upgrade is something that I will take into consideration, assuming the size of the case will not hinder the OCing potential due to heat restraints. As for GPU's, another reason I leaned towards the 750 TI over the faster AMD cards, was because a few family members happen to have Nvidia Shields, and game stream is a viable option for them. With a PC that uses very little power, leaving it on, and waking it remotely will be a far better option than streaming from a main rig. Considering games are scaled down to 720p anyways for shield streaming, the 750 TI should suffice for most games on medium-high @ 720p.
I wish I had the extra money for an SSD upgrade, as I am very partial to the Samsung 850 Pro, and I would not mind using another one for this build. I just figured I would get a cheap SSD for the OS, and use a 1TB WD red I have lying about for the additional storage. I am just hoping this build works out, as I would not mind having a PC that is of a similar size to a console, easy to leave lying around on a shelf of a TV stand.
Thanks for the suggestions!
-MageTank
