Everyone says that less is more and if you put a lot, it's not good and things like that...
But my friend runs a repair shop and he says that the more you put, the better, because your CPU and mobo around ir might be dirty, but you can clean that and it's cheaper than if your CPU dies.
What is the truth here?
Also one more thing: is the Intel stock thermal compound good, or should I replace it with a custom one (I've got a PC to build SOON, very soon :D)?
https://linustechtips.com/topic/246344-thermal-compound/
Okay to apoint if you put a tiny amount it wondt cover the die but on the contrary if you pu to much it will insulate and you should clean the die beforehand. The intle stock is shit but also thermal compound wont dramatically increase the performance of the stock cooler
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/246344-thermal-compound/#findComment-3381365
The more compound you put on after a certain point the more detrimental it gets. You need about slightly more than en uncooked grain of rice and that's it. It's what I put on my friends CPU and his CPU runs 48-50C after a few hours of aida64
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/246344-thermal-compound/#findComment-3381371
It's like asking how long is a piece of string is. It kinda depends what your friend means, he might mean one thing but we may see at as him saying something else, same goes for the less is more saying. It's probably just a misinterpretation on either his part or our part.
As for the intel thermal compound, it's okay I guess, it's not going to be anything special like MX-4
https://linustechtips.com/topic/246344-thermal-compound/#findComment-3381386
What does "detrimental" mean?
What happens then?
=having the opposite effect, making things worse rather then better (=increase temps, instead of decreasing them)
[Main rig "ToXxXiC":]
CPU: Intel Core i7-4790K | MB: ASUS Maximus VII Formula | RAM: G.Skill TridentX 32GB 2400MHz (DDR-3) | GPU: EVGA GTX980 Hydro Copper | Storage: Samsung 850 Pro 256GB SSD + Samsung 850 EVO 1TB SSD (+NAS) | Sound: OnBoard | PSU: XFX Black Edition Pro 1050W 80+ Gold | Case: Cooler Master Cosmos II | Cooling: Full Custom Watercooling Loop (CPU+GPU+MB) | OS: Windows 7 Professional (64-Bit)
https://linustechtips.com/topic/246344-thermal-compound/#findComment-3382104
OK, but why so... ?
The pea method is the best. You don't want to put too much, because you could short things out
OK... but why so?
https://linustechtips.com/topic/246344-thermal-compound/#findComment-3382978
OK, but why so... ?
OK... but why so?
Thermal paste conducts heat less efficient than direct metal to metal contact (in theory). But since the metal surfaces are not perfect, there will always be (tiny) areas where the surfaces don't really touch and you have tiny pockets of air - and air doesn't conduct heat very well at all (it's more of an isolator actually). So, thermal paste ist used to fill up all these little air pockets with something that conducts heat much better than air, but still less than direct metal to metal could. So, it's best to use only as much as is needed to fill the air pockets, but still as little as possible.
https://linustechtips.com/topic/246344-thermal-compound/#findComment-3383123
