Hello all,
Im planning on upgrading my rig to 32gb ram...
I currently have a Asrock z97 professional and a 4790K..
I want to get 32gb ram and would like a high speed set of ram, preferably 2400mhz...
Color: Black or Red
No more than $350
Any suggestions?
Thanks!
https://linustechtips.com/topic/245135-need-help-selecting-ram/
Hello all,
Color: Black or Red
No more than $350
Any suggestions?
Thanks!
Out of curiosity, what are you doing that needs so much ram?
Please use http://pcpartpicker.com/ for everybodones sake!
and quote me if you want me to see a reply please :)
pewpewpewphysicslazers!!!
https://linustechtips.com/topic/245135-need-help-selecting-ram/#findComment-3365003
Just download more at download more ram.com, Just kidding see if you can get some corsair dominator platnium kits
SYSTEM SPECS
i7 4790k | LTT Edition Noctua NH-U12S | Gigabyte Z97-SOC Force | 16GB Crucial Ballistix Tactical Tracer DDR3 | 120GB Samsung 850 EVO | 1TB Western Digital Caviar Blue | NVIDIA GTX 980ti | H440 Orange | EVGA 650B3 PSU
https://linustechtips.com/topic/245135-need-help-selecting-ram/#findComment-3365023
Running 40 virtual machines. :D:P
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/245135-need-help-selecting-ram/#findComment-3365040
This thread should've actually've been posted here: http://linustechtips.com/main/forum/5-cpus-motherboards-and-memory/ ;)
Maybe you could move this @Whiskers ?
https://linustechtips.com/topic/245135-need-help-selecting-ram/#findComment-3365054
you make me chuckle xD anyway I recommend this http://pcpartpicker.com/part/gskill-memory-f32400c10d16gtx
https://linustechtips.com/topic/245135-need-help-selecting-ram/#findComment-3365069
You make me chuckle xD.
Haha, well I'm glad I did. You know what they say, laughter is the best medicine! :D
I think you meant to recommend that to @coleg, however, I think the links dead. ;)
https://linustechtips.com/topic/245135-need-help-selecting-ram/#findComment-3365094
Needing 32GB is already something peculiar. Needing high speeds such as 2400Mhz is another thing that also makes me wonder what the hell you need that so much.
I mean, sure, 32GB of RAM might be needed if you do some serious heavy stuff but 2400MHz is not really worth the premium IMO. I'd rather settle with 2133MHz tops which are already expensive.
CPU: Intel Core i7-4790k | CPU Cooler: Noctua NH-D15 | Motherboard: ASUS Sabertooth Z97 MARK 1 | Memory: Kingston HyperX FURY 16GB 1866MHz | GPU: Gigabyte GeForce GTX 770 4GB Windforce
Storage: Samsung 840 EVO | PSU: CM Silent Pro 720W | Case: Phanteks Enthoo Luxe | Headset: Corsair Vengeance 2100 | Keyboard: Logitech G710+ | Mouse: Razer DeathAdder Chroma
"You see, one can only be angry with those he respects." - R. Nixon
https://linustechtips.com/topic/245135-need-help-selecting-ram/#findComment-3365102
oops lol thanks anyway for the chuckle xD
https://linustechtips.com/topic/245135-need-help-selecting-ram/#findComment-3365104
Oops lol thanks anyway for the chuckle xD
No worries! I give them out freely any time for whoever wants them. :D :lol:
https://linustechtips.com/topic/245135-need-help-selecting-ram/#findComment-3365145
Just so you know, there's more to RAM than just the speed and number of GB's. Latency is important too.
Here's a decent combo of speed and latency. Just so you know, RAM modules with a higher capacity tend to come with a higher latency, resulting in less system performance than having several "smaller" modules of RAM.
But here's some G.Skill RAM that should do you good.
https://linustechtips.com/topic/245135-need-help-selecting-ram/#findComment-3370210
