Adding GPU Waterblock to my Current Watercooling build. Will it hold the heat
Solved by Boink,
You should be fine, your temps will go up but not so much that your fans will need to be sped up to 100%
Give it a shot and if it really doesn't work just pop the air cooler back on your GPU.
Featured Topics
Hotblood ·
Posted in Storage Devices1 -
Nakul211 ·
Posted in Graphics Cards0 -
sweshy ·
Posted in New Builds and Planning2 -
3
Moonphase ·
Posted in Graphics Cards1 -
8
Dennettic ·
Posted in CPUs, Motherboards, and Memory22 -
Lukdtx ·
Posted in Storage Devices2 -
1
1
play_circle_filled
Latest From Linus Tech Tips:
Update Windows Before Watching This - WAN Show June 14, 2024
