Crossfire problem
Go to solution Solved by hahaman152,
I solved it. It was caused by the AMD raptr software as without this crossfire works fine.
Hi
Has anyone else encounter this problem with crossfire and the catalyst control center?
My problem is when i enable crossfire with my 2 r9 280x cards the usage on the second card is idle no matter what game ect (before restarting the PC) . I assumed one of the cards must be broken so i tried them on there own but no problems both showed gpu usage ect. so i then put both back in made sure the crossfire bridge in properly enabled crossfire and restarted. Once i logged in as soon as the catalyst control center stared the PC freezes every time. To unfreeze i have to remove the bridge log in and disable the ccc.exe then restart and that fixes it ive tried different versions of the ccc ive swapped cards round i have 1000w corsair power supply so i don't think im maxing that out. ive got the latest motherboard BIOS. Crossfire used to work before the ccc updated a few versions ago when i was playing games that needed the extra gpu power. I only noticed  it wasn't working when i enabled it for the first time in about 3 months. Any one else had this problem or a solution ?
Thanks Joe
https://linustechtips.com/topic/244755-crossfire-problem/
I'd get a full wipe of everything amd and amd catalyst and some fresh drivers.
also can we have full pc specs?
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
https://linustechtips.com/topic/244755-crossfire-problem/#findComment-3359457
Windows 7 Home Premium 64-bit SP1
AMD FX-9590
8.00GB Dual-Channel DDR3
ASUSTeK COMPUTER INC. CROSSHAIR V FORMULA-Z (Socket 942)
3072MB ATI AMD Radeon R9 200 Series (ASUStek Computer Inc) x2
931GB Western Digital WDC WD10 EZEX-22RKKA0 SATA Disk Device (SATA) 31 °C
465GB Samsung SSD 840 EVO 500G SATA Disk Device (SSD)
corsair rm 1000w psu
it was working fine until the updates happened it going to later versions dosnt seem to help and from what ive done it dosnt appear to be the cards
https://linustechtips.com/topic/244755-crossfire-problem/#findComment-3359500
Ignore the games I can't play them as when I turn computer on with crossfire enabled it freezes within ten seconds of logging in. I've worked out its the catalyst control centre that cause the crashes when I log in with crossfire enabled. I can u install it computer works fine but then I can't turn crossfire on I don't know what to do.
https://linustechtips.com/topic/244755-crossfire-problem/#findComment-3365110
