NZXT Source 210
NZXT Source 340
H440
Enthoo Pro
Define R4
Air 540
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/244285-best-white-case/#findComment-3351399
WHite H440, R4, Cm stryker, air 540
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
https://linustechtips.com/topic/244285-best-white-case/#findComment-3351405
Whatever you like best from a reputable brand, cases are all personal preference
SYSTEM SPECS
i7 4790k | LTT Edition Noctua NH-U12S | Gigabyte Z97-SOC Force | 16GB Crucial Ballistix Tactical Tracer DDR3 | 120GB Samsung 850 EVO | 1TB Western Digital Caviar Blue | NVIDIA GTX 980ti | H440 Orange | EVGA 650B3 PSU
https://linustechtips.com/topic/244285-best-white-case/#findComment-3351672
NZXT H440 springs to mind.
NZXT S340 is probably the best in terms of "value" but the H440 is a better overall case.
https://linustechtips.com/topic/244285-best-white-case/#findComment-3352060
