I am looking for a chassis for my build.
Under 150$
Cpu:
Intel i5 4460 Motherboard:Msi Z97S Sli krait Ram:HyperX Fury White (2x4) Storage:Seagate 1tb/Samsung 850 Evo 120gb Gpu:Gtx 960 2gb sc Case:S340 Black Psu:Corsair Rm 650w 80+ Gold certified
My anime list : http://myanimelist.net/animelist/KRImSIN
https://linustechtips.com/topic/243002-chassis-under-150/
Motherboard form factor? Watercooling? Anything? We need to know more.
https://linustechtips.com/topic/243002-chassis-under-150/#findComment-3329068
Corsair Carbide Air 540 is a beast for airflow.
PC : | CPU: Intel 4790K | COOLER: Corsair H105 w/ JetFlo's Push/Pull | MOBO: EVGA Z97 Classified | GPU: EVGA FTW 4GB GTX 970 X2 | RAM: Kingston HyperX Beast 1866Mhz 32GB | CASE: HAF Stacker 945 | PSU: Corsair AX1500i | DISPLAY: Asus MX299Q | SSD: 2 X Corsair Neutron GTX 480 GB in RAID0 | mSATA SSD: Samsung 840 EVO 500 GB | HDD: 4 X Western Digital RED 4 TB in JBOD |
https://linustechtips.com/topic/243002-chassis-under-150/#findComment-3329071
Switch 810 if you can get free shipping I got mine for 149.99 with free shipping.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/243002-chassis-under-150/#findComment-3329076
I just realized, you have a uselessly large case for your build. That is, if my memory serves correctly and the HAF Stacker 945 is the one with the main ATX portion and two ITX portions on the top and bottom?
https://linustechtips.com/topic/243002-chassis-under-150/#findComment-3329087
MSI Z87-G41 PC Mate ATX LGA1150 Motherboard thats my motherboard im using stock cooler. and graphics card is EVGA GeForce GTX 760 2GB Superclocked ACX Video Card.
Cpu:
https://linustechtips.com/topic/243002-chassis-under-150/#findComment-3329101
Btw using USD currency.
Cpu:
https://linustechtips.com/topic/243002-chassis-under-150/#findComment-3329102
NZXT H440 is perfect.   :rolleyes:
This is Comic Sans.
This is Comic Sans.                                If you can't tell the difference, you may need to see a specialist.
This is Comic Sans.
https://linustechtips.com/topic/243002-chassis-under-150/#findComment-3329114
Cpu:
https://linustechtips.com/topic/243002-chassis-under-150/#findComment-3329136
I wouldn't say useless, I would say having 3 SSDs, 4 HDDs, 2 Blu-ray burner, a H105 rad in the upper part to get my 4790K temp at 45C full LOAD and having no obstruction at all in front of my two graphics cards in SLI is really nice while having a so small footprint.
https://linustechtips.com/topic/243002-chassis-under-150/#findComment-3329145
It's okay, but a bit big. If you want it to be smaller, the Arc Midi R2 is good too.
https://linustechtips.com/topic/243002-chassis-under-150/#findComment-3329148
Silverstone TJ04B-E (-EW for window)
Silverstone KL04B (Add "-W" for window)
NZXT S340
NZXT H440
Fractal Design Arc Midi R2
Phanteks Enthoo Pro
Corsair 450D
Corsair Air 540
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/243002-chassis-under-150/#findComment-3329175
If you have all this money to spend on the case, the least you can do is get a Hyper 212 EVO....
Also, get a Define R4/NZXT H440. I doubt you need an absolutely giant case. See one in person and decide if you really want something bigger than a standard ATX case.
https://linustechtips.com/topic/243002-chassis-under-150/#findComment-3329288
  • 3 weeks later...
