So I've managed to overclock my FX-8350 to 4.2Ghz just by changing the multipliers in the bios menu to 21x and without touching the voltages. The temps seem pretty stable running Prime95 for an hour or so with max of 70 Celsius and with a Hyper 212 evo. If i wanted to overclock further, say to 4.4, what would i need to do to the voltages? I have no clue how much higher I need to increase the voltages from the stock value.
https://linustechtips.com/topic/242991-changing-voltage-when-overclocking-fx-8350/
Nothing unless it's not stable.
This and have you disabled turbo and set voltage to manual? 70c is 8c over the 'safe limit'.
It depends of your CPU, all FX-8350 don't overclock the same way. With an Intel processor you would get better real performance per frequency overclock.
PC : | CPU: Intel 4790K | COOLER: Corsair H105 w/ JetFlo's Push/Pull | MOBO: EVGA Z97 Classified | GPU: EVGA FTW 4GB GTX 970 X2 | RAM: Kingston HyperX Beast 1866Mhz 32GB | CASE: HAF Stacker 945 | PSU: Corsair AX1500i | DISPLAY: Asus MX299Q | SSD: 2 X Corsair Neutron GTX 480 GB in RAID0 | mSATA SSD: Samsung 840 EVO 500 GB | HDD: 4 X Western Digital RED 4 TB in JBOD |
Since you are running an evo 212 I would say as long as you keep prime under 90c up the voltage to the max to get the most ghz. You will hit your temp limits before your voltage limits unlike with intel cpu's.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
AMD state that the max temp for that CPU is 62c.
I am also running that CPU overclocked to 4.2Ghz and my max temp never goes over 55c ON AIR when CPU is at 100%.  not sure why yours is running that hot.
I am using Gelid Black Edition CPU Cooler.
Official Profile for Addon Customs LTD and Custom Acrylics
Addon Customs -
Custom LED Lighting | Single colour and RGB available, hand sleeved | Now making Phanteks Case compatible LED KITS
Custom Acrylics - Custom computer parts | GPU backplates, Fan Grills, NZXT H440 Fascias and PSU covers | 3D printing and Laser Cutting Service available.
Personally, your temps seem a little bit high, so I would do a fresh thermal paste job and remount the cooler. But depending on your chip, you might not even have to touch the voltages.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
