I just started to get into folding but it seems that my work unit for my gpu is stuck at 99.9% and says ETA 1 second, but it is stuck there. I already checked the FAQ and it said it was something related to not being able to connect to the server, but I did not find anything like that in the log files.
Here is some of the log from overnight.
"*********************** Log Started 2014-10-30T02:20:25Z ***********************
02:20:25:************************* Folding@home Client *************************
02:20:25:      Website: http://folding.stanford.edu/
02:20:25:    Copyright: © 2009-2014 Stanford University
02:20:25:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:20:25:         Args:
02:20:25:       Config: C:/Users/Brian/AppData/Roaming/FAHClient/config.xml
02:20:25:******************************** Build ********************************
02:20:25:      Version: 7.4.4
02:20:25:         Date: Mar 4 2014
02:20:25:         Time: 20:26:54
02:20:25:      SVN Rev: 4130
02:20:25:       Branch: fah/trunk/client
02:20:25:     Compiler: Intel® C++ MSVC 1500 mode 1200
02:20:25:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
02:20:25:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
02:20:25:     Platform: win32 XP
02:20:25:         Bits: 32
02:20:25:         Mode: Release
02:20:25:******************************* System ********************************
02:20:25:          CPU: Intel® Core i7-3770K CPU @ 3.50GHz
02:20:25:       CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
02:20:25:         CPUs: 8
02:20:25:       Memory: 15.97GiB
02:20:25:  Free Memory: 14.40GiB
02:20:25:      Threads: WINDOWS_THREADS
02:20:25:   OS Version: 6.2
02:20:25:  Has Battery: false
02:20:25:   On Battery: false
02:20:25:   UTC Offset: -4
02:20:25:          PID: 6128
02:20:25:          CWD: C:/Users/Brian/AppData/Roaming/FAHClient
02:20:25:           OS: Windows 8.1 Pro
02:20:25:      OS Arch: AMD64
02:20:25:         GPUs: 1
02:20:25:        GPU 0: ATI:5 Tahiti XT [Radeon R9 200/HD 7900/8970]
02:20:25:         CUDA: Not detected
02:20:25:Win32 Service: false
02:20:25:***********************************************************************
02:20:25:<config>
02:20:25:  <!-- Folding Slot Configuration -->
02:20:25:  <cause v='ALZHEIMERS'/>
02:20:25:
02:20:25:  <!-- Slot Control -->
02:20:25:  <power v='FULL'/>
02:20:25:
02:20:25:  <!-- User Information -->
02:20:25:  <passkey v='********************************'/>
02:20:25:  <team v='223518'/>
02:20:25:  <user v='BrianPena'/>
02:20:25:
02:20:25:  <!-- Folding Slots -->
02:20:25:  <slot id='0' type='CPU'>
02:20:25:    <paused v='true'/>
02:20:25:  </slot>
02:20:25:  <slot id='1' type='GPU'>
02:20:25:  </slot>
02:20:25:</config>
02:20:25:Trying to access database...
02:20:25:Successfully acquired database lock
02:20:25:Enabled folding slot 00: PAUSED cpu:7 (by user)
02:20:25:Enabled folding slot 01: PAUSED gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970] (by user)
06:13:30:12:127.0.0.1:New Web connection
06:13:37:FS00:Unpaused
06:13:37:FS01:Unpaused
06:13:37:WU02:FS00:Starting
06:13:37:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Brian/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 02 -suffix 01 -version 704 -lifeline 6128 -checkpoint 15 -np 7
06:13:37:WU02:FS00:Started FahCore on PID 2776
06:13:38:WU02:FS00:Core PID:7280
06:13:38:WU02:FS00:FahCore 0xa3 started
06:13:38:WU01:FS01:Starting
06:13:38:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Brian/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 6128 -checkpoint 15 -gpu 0 -gpu-vendor ati
06:13:38:WU01:FS01:Started FahCore on PID 4800
06:13:38:WU02:FS00:0xa3:
06:13:38:WU02:FS00:0xa3:*------------------------------*
06:13:38:WU02:FS00:0xa3:Folding@Home Gromacs SMP Core
06:13:38:WU02:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
06:13:38:WU02:FS00:0xa3:Preparing to commence simulation
06:13:38:WU02:FS00:0xa3:- Looking at optimizations...
06:13:38:WU02:FS00:0xa3:- Files status OK
06:13:38:WU02:FS00:0xa3:- Expanded 3811396 -> 4182748 (decompressed 109.7 percent)
06:13:38:WU02:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3811396 data_size=4182748, decompressed_data_size=4182748 diff=0
06:13:38:WU02:FS00:0xa3:- Digital signature verified
06:13:38:WU02:FS00:0xa3:Project: 6095 (Run 1, Clone 73, Gen 29)
06:13:38:WU01:FS01:Core PID:5740
06:13:38:WU02:FS00:0xa3:Assembly optimizations on if available.
06:13:38:WU01:FS01:FahCore 0x17 started
06:13:38:WU02:FS00:0xa3:Entering M.D.
06:13:39:WU01:FS01:0x17:*********************** Log Started 2014-10-30T06:13:38Z ***********************
06:13:39:WU01:FS01:0x17:Project: 9201 (Run 66, Clone 1, Gen 73)
06:13:39:WU01:FS01:0x17:Unit: 0x000000a46652edc45399d8a1a1c4c0e1
06:13:39:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
06:13:39:WU01:FS01:0x17:Machine: 1
06:13:39:WU01:FS01:0x17:Digital signatures verified
06:13:39:WU01:FS01:0x17:Folding@home GPU core17
06:13:39:WU01:FS01:0x17:Version 0.0.52
06:13:39:WU01:FS01:0x17:  Found a checkpoint file
06:13:44:WU02:FS00:0xa3:Using Gromacs checkpoints
06:13:44:WU02:FS00:0xa3:Mapping NT from 7 to 7
06:13:45:WU02:FS00:0xa3:Resuming from checkpoint
06:13:45:WU02:FS00:0xa3:Verified 02/wudata_01.log
06:13:45:WU02:FS00:0xa3:Verified 02/wudata_01.trr
06:13:45:WU02:FS00:0xa3:Verified 02/wudata_01.edr
06:13:45:WU02:FS00:0xa3:Completed 90205 out of 500000 steps  (18%)
06:14:04:WU01:FS01:0x17:Completed 400000 out of 5000000 steps (8%)
06:14:04:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:14:15:Saving configuration to config.xml
06:14:15:<config>
06:14:15:  <!-- Folding Slot Configuration -->
06:14:15:  <cause v='ALZHEIMERS'/>
06:14:15:
06:14:15:  <!-- Slot Control -->
06:14:15:  <power v='FULL'/>
06:14:15:
06:14:15:  <!-- User Information -->
06:14:15:  <passkey v='********************************'/>
06:14:15:  <team v='223518'/>
06:14:15:  <user v='BrianPena'/>
06:14:15:
06:14:15:  <!-- Folding Slots -->
06:14:15:  <slot id='0' type='CPU'/>
06:14:15:  <slot id='1' type='GPU'/>
06:14:15:</config>
06:16:57:WU01:FS01:0x17:Completed 450000 out of 5000000 steps (9%)
06:19:53:WU01:FS01:0x17:Completed 500000 out of 5000000 steps (10%)
06:22:47:WU01:FS01:0x17:Completed 550000 out of 5000000 steps (11%)
06:22:52:WU02:FS00:0xa3:Completed 95000 out of 500000 steps  (19%)
06:25:40:WU01:FS01:0x17:Completed 600000 out of 5000000 steps (12%)
06:28:34:WU01:FS01:0x17:Completed 650000 out of 5000000 steps (13%)
06:31:27:WU01:FS01:0x17:Completed 700000 out of 5000000 steps (14%)
06:32:03:WU02:FS00:0xa3:Completed 100000 out of 500000 steps  (20%)
06:34:20:WU01:FS01:0x17:Completed 750000 out of 5000000 steps (15%)
06:37:14:WU01:FS01:0x17:Completed 800000 out of 5000000 steps (16%)
06:40:07:WU01:FS01:0x17:Completed 850000 out of 5000000 steps (17%)
06:40:52:WU02:FS00:0xa3:Completed 105000 out of 500000 steps  (21%)
06:43:00:WU01:FS01:0x17:Completed 900000 out of 5000000 steps (18%)
06:45:52:WU01:FS01:0x17:Completed 950000 out of 5000000 steps (19%)
06:48:45:WU01:FS01:0x17:Completed 1000000 out of 5000000 steps (20%)
06:49:39:WU02:FS00:0xa3:Completed 110000 out of 500000 steps  (22%)
06:51:38:WU01:FS01:0x17:Completed 1050000 out of 5000000 steps (21%)
06:54:30:WU01:FS01:0x17:Completed 1100000 out of 5000000 steps (22%)
06:57:23:WU01:FS01:0x17:Completed 1150000 out of 5000000 steps (23%)
06:58:25:WU02:FS00:0xa3:Completed 115000 out of 500000 steps  (23%)
07:00:16:WU01:FS01:0x17:Completed 1200000 out of 5000000 steps (24%)
07:03:08:WU01:FS01:0x17:Completed 1250000 out of 5000000 steps (25%)
07:06:01:WU01:FS01:0x17:Completed 1300000 out of 5000000 steps (26%)
07:07:13:WU02:FS00:0xa3:Completed 120000 out of 500000 steps  (24%)
07:08:54:WU01:FS01:0x17:Completed 1350000 out of 5000000 steps (27%)
07:11:47:WU01:FS01:0x17:Completed 1400000 out of 5000000 steps (28%)
07:14:39:WU01:FS01:0x17:Completed 1450000 out of 5000000 steps (29%)
07:16:01:WU02:FS00:0xa3:Completed 125000 out of 500000 steps  (25%)
07:17:32:WU01:FS01:0x17:Completed 1500000 out of 5000000 steps (30%)
07:20:24:WU01:FS01:0x17:Completed 1550000 out of 5000000 steps (31%)
07:24:44:WU02:FS00:0xa3:Completed 130000 out of 500000 steps  (26%)
07:33:19:WU02:FS00:0xa3:Completed 135000 out of 500000 steps  (27%)
07:41:54:WU02:FS00:0xa3:Completed 140000 out of 500000 steps  (28%)
07:50:29:WU02:FS00:0xa3:Completed 145000 out of 500000 steps  (29%)
07:59:10:WU02:FS00:0xa3:Completed 150000 out of 500000 steps  (30%)
08:07:45:WU02:FS00:0xa3:Completed 155000 out of 500000 steps  (31%)
08:16:21:WU02:FS00:0xa3:Completed 160000 out of 500000 steps  (32%)
******************************* Date: 2014-10-30 *******************************
08:24:57:WU02:FS00:0xa3:Completed 165000 out of 500000 steps  (33%)
08:33:33:WU02:FS00:0xa3:Completed 170000 out of 500000 steps  (34%)
08:42:09:WU02:FS00:0xa3:Completed 175000 out of 500000 steps  (35%)
08:50:45:WU02:FS00:0xa3:Completed 180000 out of 500000 steps  (36%)
08:59:21:WU02:FS00:0xa3:Completed 185000 out of 500000 steps  (37%)
09:07:57:WU02:FS00:0xa3:Completed 190000 out of 500000 steps  (38%)
09:16:33:WU02:FS00:0xa3:Completed 195000 out of 500000 steps  (39%)
09:25:10:WU02:FS00:0xa3:Completed 200000 out of 500000 steps  (40%)
09:33:45:WU02:FS00:0xa3:Completed 205000 out of 500000 steps  (41%)
09:42:21:WU02:FS00:0xa3:Completed 210000 out of 500000 steps  (42%)
09:50:56:WU02:FS00:0xa3:Completed 215000 out of 500000 steps  (43%)
09:59:32:WU02:FS00:0xa3:Completed 220000 out of 500000 steps  (44%)
10:08:08:WU02:FS00:0xa3:Completed 225000 out of 500000 steps  (45%)
10:16:42:WU02:FS00:0xa3:Completed 230000 out of 500000 steps  (46%)
10:25:18:WU02:FS00:0xa3:Completed 235000 out of 500000 steps  (47%)
10:33:53:WU02:FS00:0xa3:Completed 240000 out of 500000 steps  (48%)
10:42:28:WU02:FS00:0xa3:Completed 245000 out of 500000 steps  (49%)
10:51:04:WU02:FS00:0xa3:Completed 250000 out of 500000 steps  (50%)
10:59:39:WU02:FS00:0xa3:Completed 255000 out of 500000 steps  (51%)
11:08:14:WU02:FS00:0xa3:Completed 260000 out of 500000 steps  (52%)
11:16:48:WU02:FS00:0xa3:Completed 265000 out of 500000 steps  (53%)
11:25:22:WU02:FS00:0xa3:Completed 270000 out of 500000 steps  (54%)
11:33:56:WU02:FS00:0xa3:Completed 275000 out of 500000 steps  (55%)
11:42:30:WU02:FS00:0xa3:Completed 280000 out of 500000 steps  (56%)
11:51:04:WU02:FS00:0xa3:Completed 285000 out of 500000 steps  (57%)
11:59:38:WU02:FS00:0xa3:Completed 290000 out of 500000 steps  (58%)
12:08:13:WU02:FS00:0xa3:Completed 295000 out of 500000 steps  (59%)
12:16:48:WU02:FS00:0xa3:Completed 300000 out of 500000 steps  (60%)
12:25:22:WU02:FS00:0xa3:Completed 305000 out of 500000 steps  (61%)
12:33:56:WU02:FS00:0xa3:Completed 310000 out of 500000 steps  (62%)
12:42:28:WU02:FS00:0xa3:Completed 315000 out of 500000 steps  (63%)
12:51:01:WU02:FS00:0xa3:Completed 320000 out of 500000 steps  (64%)
12:59:34:WU02:FS00:0xa3:Completed 325000 out of 500000 steps  (65%)
13:08:06:WU02:FS00:0xa3:Completed 330000 out of 500000 steps  (66%)
13:16:39:WU02:FS00:0xa3:Completed 335000 out of 500000 steps  (67%)
13:25:12:WU02:FS00:0xa3:Completed 340000 out of 500000 steps  (68%)
13:33:46:WU02:FS00:0xa3:Completed 345000 out of 500000 steps  (69%)
13:40:48:FS00:Paused"
My PC: i7 3770k @ 4.4 Ghz || Hyper 212 Evo || Intel Extreme Motherboard DZ77GA || EVGA Hybrid 980ti || Corsair Vengeance Blue 16GB || Samsung 840 Evo 120 GB || WD Black 1TB
Peripherals: Corsair K70 RGB || Sentey Pro Revolution Gaming Mouse || Beyerdynamic DT 990 Premium 250 Ohm Headphone || Benq XL2420Z Monitor
https://linustechtips.com/topic/241571-problem-with-999-gpu/
Perhaps the server went down and you need to retry in a bit? Based on what you've said, I'm assuming you've tried troubleshooting it from the information given in the FAQ section of the subforum, so try holding on for a while or restarting your computer to see if that helps. Best of luck and happy folding! :)
PS- Correct me if I'm wrong please (I'm a bit new myself) but does 69% mean that it's completed only 69% of the WU [see "spoiler"]. If that's the case, try restarting you F@H client [shut it from the task manager] and pressing the folding button thereafter.
PC in Profile
https://linustechtips.com/topic/241571-problem-with-999-gpu/#findComment-3311143
this is something that can happen if the wu is incorrectly paused or interrupted, it can get stuck like that without actually being at 99% at all.
Try to pause the slot, wait for abit, close the client completely, restart the client and resume the wu(unpause), that should do the trick and it will likely restart from 69% where it actually is.
give us a call if that doesn't work, you might have to dump the wu, but i really don't think that will be necessary.
*snip*
hehe, seems like we got an enthusiast on our hands. The deduction you made should indeed be correct.
https://linustechtips.com/topic/241571-problem-with-999-gpu/#findComment-3311706
According to the log:
This is the CPU slot - it has been "paused" and is at 69%
But the last thing we see about the GPU slot is:
So, ya, a reboot may be in order.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/241571-problem-with-999-gpu/#findComment-3313110
Yeah I'm at my work computer right now so I can't do much at the moment. I did happen to restart it before I left and it started up at 31%. Problem is I did this a couple of days ago as well and it just ended up at 99.9% again. I have it running at home right now so I guess we will just have to wait and see.
https://linustechtips.com/topic/241571-problem-with-999-gpu/#findComment-3313148
If worse comes to worse and this keeps happening, may be a bad WU and you will need to delete it.
http://linustechtips.com/main/topic/207857-for-folding-users-tips-tricks-and-faq-updated-aug-2014/How to delete a Work Folder (to clear up stuck WU's)
https://linustechtips.com/topic/241571-problem-with-999-gpu/#findComment-3313165
ops  :blink: , i didn't see that. Just assumed he had isolated it to one slot as he seems pretty well oriented.
Going abit off topic to something you said in another thread about folding on 600+ series for nvida gpu's.
Really? i would have assumed 500 series is still well within support. Plenty of people have older gpu's.
And while not top notch 500 series still isn't half bad.
https://linustechtips.com/topic/241571-problem-with-999-gpu/#findComment-3313543
Doh, you are right, not sure where my head is at considering I am running two 560's :)
I think Nvidia side the lowest now is 400 series and AMD side the lowest is 6000 series... maybe that is where I pulled the 600 from? :)
https://linustechtips.com/topic/241571-problem-with-999-gpu/#findComment-3315937
or maybe just a small typo :P, had me wondering if 500 series was borderline out of support.
https://linustechtips.com/topic/241571-problem-with-999-gpu/#findComment-3319976
It looks like it's fixed guys. Thankfully I didn't have to delete the WU. Folding is going strong as we speak!
https://linustechtips.com/topic/241571-problem-with-999-gpu/#findComment-3320684
Excellent to hear!
https://linustechtips.com/topic/241571-problem-with-999-gpu/#findComment-3323337
