I am starting to have this wierd thing where if I leave my system on and walk away and comeback my system freezes up and I have to hit eh power button, I am currently overclocked but it was happening prior, so I am turning of my OC but I still had this problem before. I have the sniper 5, 4770k, 780 ti, 500gb ssd samsung, 3tb segate HDD, corsair rm850, corsair vengense pro 2133 ram. h100i cooler, any ideas what this could be? I am guessing maybe the mobo, but I am terrible with trouble shooting still, this was my first build, any suggestions would help thanks.
Mouse: Razer Death Adder 2013 Keybaord: Razer Black Widow Ultimate 2013
https://linustechtips.com/topic/241395-system-lock-ups/
Over heating, check your temperatures.
CPU temps do not go above 65c underloadish, this typically happens after idle time, idle temps are around 30ish Celcius. Stress tested with the oc does not go above 82c.
https://linustechtips.com/topic/241395-system-lock-ups/#findComment-3308939
Any other ideas?
Maybe bad RAM, a driver issue, or possibly a bad Windows installation
Desktop: Intel Core i5 2380P (2400 w/o iGPU), MSI H61, 8GB RAM, 256GB SP610, 500GB WD Blue, HIS R9 280, Antec TruePower Classic 550W, Inwin MANA 134, QNIX QX2710, CM QuickFire Rapid, Logitech G402
Laptop: Toshiba Satellite L40D, AMD A6-6310, 6GB RAM, 500GB HDD, Radeon R4 Graphics, 14" 1366x768
Phone: iPhone 6 Space Gray 64GB, T-Mobile $60/mo 3GB plan
https://linustechtips.com/topic/241395-system-lock-ups/#findComment-3308972
Ill re install all my drivers tomorrow, and will try to check the ram. Really hope its not the windows install. Thanks for the input.
https://linustechtips.com/topic/241395-system-lock-ups/#findComment-3309032
Update your bios.how long have you had this PC, how long have you had this problem?
I have had it for 8 months, I started noticing this maybe 4 months ago, very rarely did not pay attention to it, have not updated the bios ever so Ill try doing that.
https://linustechtips.com/topic/241395-system-lock-ups/#findComment-3311176
Hello!
Are you using Chrome? This is the most recent thing that comes to mind- I wake my computer from sleep/ standby, go on a YouTube page, and my computer freezes. If that's not the case, I suggest eliminating each part one my one-
CPU- Prime 95 for 24 hours
RAM- Memtest 86+ for 24 hous
GPU- Any benchmarking tool such as 3DMark 11 for 12 hours
PSU- Full system load (try folding) for 24 hours.
If anything fails/ system crashes during these tests, it's the part you are testing for.
I hope this helps! :)
PC in Profile
https://linustechtips.com/topic/241395-system-lock-ups/#findComment-3311329
Hello!
Interesting, I still need to try bios update will stress test, except instead of prime 95 Aida, and no I am using Firefox do not even have chrome installed. It did get better once I turned off my oc, temps were under control and now under gaming while having like 10 web pages open watching 1080p video, and sky ping with spotify on, my temps actually did not go down any from turning the overclock of should not be CPU over heating. Taking a guess maybe something with the mobo.
https://linustechtips.com/topic/241395-system-lock-ups/#findComment-3331497
