I plan to use this mostly for video editing but my budget is kinda tight so I can't get Quadros and Xeons yet but I plan to upgrade to them
PCPartPicker part list: http://pcpartpicker.com/p/ZsjgCJ
Price breakdown by merchant: http://pcpartpicker.com/p/ZsjgCJ/by_merchant/
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($299.99 @ Micro Center)
CPU Cooler: Noctua NH-U14S 55.0 CFM CPU Cooler  ($69.99 @ Newegg)
Motherboard: Asus X99-E WS SSI CEB LGA2011-3 Motherboard  ($511.98 @ SuperBiiz)
Memory: Crucial 16GB (2 x 8GB) DDR4-2133 Memory  ($194.99 @ Adorama)
Storage: Samsung XP941 Series 256GB M.2-2280 Solid State Drive  ($249.99 @ Newegg)
Video Card: EVGA GeForce GTX 980 4GB Superclocked Video Card  ($644.99 @ B&H)
Power Supply: Corsair Professional 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($132.99 @ Best Buy)
Monitor: LG 34UC97-S 60Hz 34.0" Monitor  ($1299.00 @ Adorama)
Total: $3403.92
Generated by PCPartPicker 2014-10-29 12:09 EDT-0400
+ a ThunderboltEX 2 dual
I don't have a case yet because most SSI-CEB cases I've seen seems too fancy and over the top, if anyone has a case recommendation, I would greatly appreciate it ( preferably a clean case along the lines of the Fractal Design Define cases )
| --- My Stuff --- |
Computer: Apple Late-2008 Macbook Pro ; -Haguro- build: http://linustechtips.com/main/topic/296613-wip-project-haguro-x99-hackintosh-workstation/|
Mobile Devices: Apple 32GB 1st gen Ipad Mini ; Apple 16GB Iphone 5s ; Apple Ipod Classic 80Gb 5th Gen ; Apple Ipod Classic 120Gb 6th Gen ; Apple Ipod Classic 160Gb 7th Gen ; Apple Ipod Nano 16Gb 6th Gen
https://linustechtips.com/topic/241062-build-plan-does-everything-look-ok/
Looks fine to me
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
Silverstone Tek SSI-CEB, ATX, Micro-ATX Full Tower Computer Case with Plastic Front Panel, Steel Body and Window Side Panel Cases KL04B-W (Black)
oh I saw micro atx O.o
Does not look bad, but why does the motherboard cost so much?
It's a WS (workstation) board
Thanks, that looks like a really nice case, how did I miss it before, I wonder?
If anyone owns the KL04B, can you tell me your experience with it (does it hold up well?, is it nice to work in?) because I probably will have to ship it half way around the world and I hope that it hold up well (If anyone has a suggestion for a good shipping service to Viet Nam, that would be nice too, thanks in advance)
| --- My Stuff --- |
Its cool :D.
Also the monitor you're going to get is really nice.
Yea, when I saw LTT's review on the 34UM95, I fell in love with the monitor, now that the 34UC97 has thunderbolt 2 and a slight curve, I just couldn't resist getting it :P
| --- My Stuff --- |
You should be able to mount it in a Fractal Design Define case.  SSI-CEB has the same mounting points as ATX.
that's great then, I might get a XL R2 then
I plan to use my XP941 as a boot and software drive but I've seen people saying that on certain boards, you cannot boot using a XP941, can someone verify whether that is true or not? It would be a shame to buy one of the fastest drives on the market just to realise that you can't boot from it :P
| --- My Stuff --- |
Didn't realize you live in Vietnam, thats a long way to ship a case.
yea, I'm still trying to figure out how to get a screen and a case oversea without completely destroying them, it's kind of a pain to live so far away from things you need, especially when it's tech stuff
| --- My Stuff --- |
You could move, just kidding thats harder then trying to ship stuff... Also your family. But i could beta test your monitor for you :P
Can someone please give me the answer to this question? I really want to know whether I can boot from it, I'm sick of slow boot / software startup, thanks
| --- My Stuff --- |
I've never heard of those, you could get a crucial SSD for 50 dollars cheaper, and it will still boot fast.
XP941 is a x4 m.2 drive, it's probably the fastest single commercial drive out there right now. I would prefer not to use an ssd because I really want to take advantage of the x4 m.2 that the x99 e ws has to offer
heres a benchmark of the XP941 http://www.tweaktown.com/reviews/6372/samsung-xp941-512gb-m-2-pcie-ssd-review/index6.html
The write speed might not be as fast as other ssds but I don't think I need extremely high write speed for an OS / Software drive ( I'll probably cache and export to a hard drive )
| --- My Stuff --- |
According to Anandtech's review of the XP941 (as of May 2014), only the AsRock Z97 Extreme 6 was able to boot from it from the start, but Asus was going to update the BIOS on all their Z97 boards to boot from the XP941.
Review: http://www.anandtech.com/show/8006/samsung-ssd-xp941-review-the-pcie-era-is-here/3
Thanks alot for the info
| --- My Stuff --- |
SSI-CEB is exactly like ATX, but at a longer length of 10.5" vs 9.6" on the ATX. If a case can fit in a E-ATX then it should also fit a SSI-CEB. Depending on the case, the extra length from the board you picked, might block the rubber grommet holes for your PSU and other cable routing.
ATX: 12" x 9.6"
SSI-CEB: 12" x 10.5"
E-ATX and SSI-EEB is 12" x 13", The mounting holes for SSI-EEB is slight off from the E-ATX, that means a E-ATX case may not work with a SSI-EEB board.
ATX: 12" x 9.6"
So most E-ATX, XL-ATX, HPTX cases should be fine right?
| --- My Stuff --- |
Yeah, most should do for a SSI-CEB board. However E-ATX cases may not work with a XL-ATX board. Standard cases have 7 i/o slots. XL-ATX needs one with at least 8-9 i/o slots.  And the HTPX case out there that I know of, is the Corsair 900D and Lian Li D8000
E-ATX: 12" x 13"
XL-ATX: 13.5" x 10.3"
HPTX: 13.6" x 15"
