My h440 looks so dark in it, my mobo and black and red and the 295x2 glows red. Should I go with a red led at the top or white?
Would like some opinions :#
CPU -  Intel i7 4770k 4.6Ghz     Motherboard - MSI GD-65    RAM - Corsair Vengeance 16 GB     GPU - XFX 295x2    Case - NZXT H440
Storage - 256GB OCZ Vertex 4 ssd, 1TB WD Blue 7200rpm    PSU -  EVGA SuperNOVA 850 G2  Cooling - Corsair H80i     Keyboard - KGParadise v60 w/ cherry mx greens
Mouse -Theron  Sound - HyperX Cloud
https://linustechtips.com/topic/241006-which-led-color/
Red.
Or a mix of red + white or something.
https://linustechtips.com/topic/241006-which-led-color/#findComment-3303570
Red.
this red + white
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/241006-which-led-color/#findComment-3303584
OK you said your mobo is red and black, that means if you do put red LEDs it will look really bad trust me, go with white LEDs they will bring out the red accents and it will look sweet
I concur. White led would make it look nice. You don't want to drown it in red light.
https://linustechtips.com/topic/241006-which-led-color/#findComment-3303708
Mostly red, I was about to answer white since most people have a red/black build and white draws the red out soooo well. But for white red contrasts like a beast!
Do not  as I  do, and  not  as I say. Instead do as you may..
HSS Revenir: CPU=i7 5960x @4.5GHz Heatsink=Corsair H100i MOBO=ROG Rampage 5 RAM=Kingston HyperX Predator 16GB @3000MHz SSD=Corsair Neutron GTX 480GB GPU=R9 295x2 PSU=Corsair AX1500i OS=Windows 7 Ultimate
https://linustechtips.com/topic/241006-which-led-color/#findComment-3304371
Think im going to go with white since I think red would make it overbearing.
https://linustechtips.com/topic/241006-which-led-color/#findComment-3306269
