Where are you shopping/located? Currency?
What are you planning to power?
https://linustechtips.com/topic/239703-psu-for-100-or-less/#findComment-3286763
EVGA is a fine PSU maker BUT I am assuming you want
THE BEST!
so here it is:
Seasonic is by far the best.
Here are two options for 750W (mod vs nonmod in $25 price diff.)
http://pcpartpicker.com/part/seasonic-power-supply-ssr750rm
and
http://pcpartpicker.com/part/seasonic-power-supply-s12g750
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
https://linustechtips.com/topic/239703-psu-for-100-or-less/#findComment-3286772
America, USD, and gaming
Reread the question..
https://linustechtips.com/topic/239703-psu-for-100-or-less/#findComment-3286792
What you mean
^What system are you planning to power?
https://linustechtips.com/topic/239703-psu-for-100-or-less/#findComment-3286819
a custom built deskop
I'm asking for the specs..
https://linustechtips.com/topic/239703-psu-for-100-or-less/#findComment-3286840
Asus m5a97 le r2.0 motherboard
amd fx 8320 cpu
32g ram ddr3 1600
3tb hdd
msi gtx 760 2gb
mid tower case
4 crosair case fans
samsung 840 evo 128 gb ssd
Why such a large psu? Are you planning to sli?
https://linustechtips.com/topic/239703-psu-for-100-or-less/#findComment-3286884
http://www.ncix.com/detail/evga-supernova-750-b1-750w-34-97306-1053.htm
The B1 is fine.  I believe someone linked a really good review from jonnyguru the other day saying these rated well.
... and now I can't find it.  I only can find a B2 review from them but look at this here ...
http://www.hitechlegion.com/reviews/power-supplies/41110-evga-supernova-nex750b-power-supply-review?showall=&start=3
Definitely rates well and to get a psu after rebate for $59 is well awesome.
Here is the video on it ...
Too many ****ing games!  Back log 4 life! :S
https://linustechtips.com/topic/239703-psu-for-100-or-less/#findComment-3286886
whatever will run it and not break down
So.. yes? No? Are you planning to sli?
https://linustechtips.com/topic/239703-psu-for-100-or-less/#findComment-3286910
no
If you're not planning to sli, a decent 500w would already be more than enough: http://pcpartpicker.com/part/corsair-power-supply-cx500m
https://linustechtips.com/topic/239703-psu-for-100-or-less/#findComment-3287061
THE BEST!
so here it is:
and
Seasonic are very good, but the EVGA G2 is a better psu.
https://linustechtips.com/topic/239703-psu-for-100-or-less/#findComment-3288001
