So The time is approaching when I can afford a 980!!! I really want to buy a card no compromise card, Like the EVGA 04G-2982-KR GeForce GTX 980. http://www.newegg.com/Product/Product.aspx?Item=N82E16814487068. Is it worth paying the premium over something like the
EVGA 04G-2983-KR GeForce GTX 980? http://www.newegg.com/Product/Product.aspx?Item=N82E16814487079? The difference is minimal from what I can see, yet the price is so radically different. I like saving the money when I can, but I want to make sure there isn't that much of a difference before I buy one or the other. The money isn't as important as the performance, I'm looking from a  price to performance ratio. What do you guys think? Any other card suggestions? Will the rest of my build be bottleneck free with the card upgrade?
Build:
p8h61-m le r2.0. mobo
i5-3570k
amd 6850
8 gb gskill ripjaws 1600mhz
500 watt corsair psu
2 tb hdd
500 gb hdd
win 8.1
https://linustechtips.com/topic/239474-gtx-980-buying-help/
IMO 980 isn't worth paying double the cost of a 970 for a 20% performance increase.
"Rawr XD"
https://linustechtips.com/topic/239474-gtx-980-buying-help/#findComment-3283806
The one with the ACX dual-fan cooler should be able to disperse more heat than the one with the single-fan blower cooler. Dispersing more heat should allow for higher overclocking potential..
That being said, from what I've seen most GTX 980s are able to run around 1500 Mhz easily, and some of the high-end dual-fan coolers can run ~1550 Mhz or so.. While having an extra 50 Mhz is always nice, it isn't really worth it if the price difference is big.
Anywhoo, like Aniallation said, the GTX 970 offers fairly close performance and a substantially lower price. If price/performance is your primary concern, the 970 may be a better choice.
i7 not perfectly stable at 4.4.. #firstworldproblems
https://linustechtips.com/topic/239474-gtx-980-buying-help/#findComment-3283841
I don't think the difference justifies the price premium. I'd personally just avoid the 980 and go for a 970, seeing how the performance difference isn't very drastic.
Oh, dang. I tought he was build a pc. But I think Zotac AMP. as it is cheapest on pcpartpicker
Everyone's guilty of making a post without reading the OP sometimes. Be more vigilant! So you can be more helpful.
Like watching Anime? Consider joining the unofficial LTT Anime Club Heaven Society~ ^.^
https://linustechtips.com/topic/239474-gtx-980-buying-help/#findComment-3283859
On Evga website, the acx 2.0 version is cheaper and obviously is cooler. Both are great anyway. I have one myself, too bad it doesn't have a backplate but it's ok.
PC1 = i7 4790k  -  Asus Z97 Mark1  -  Corsair Dominator 32GB kit  -  Evga GTX 780Ti SC x2 SLI  -  SSD 512GB x2  -  12TB NAS  -  Carbide Air540  -  24" 120Hz x2 3D ready  -  Corsair K95 + M95
Custom Watercooling loop with low profile radiators / fans
PC2 = i7 4770k  -  Z97 Maximus VII Hero  -  16 GB kit  -  Evga GTX 980 SC ACX 2.0  -  Graphite 760T  -  24" VE248 x2  -  Corsair K70RGB + M90
https://linustechtips.com/topic/239474-gtx-980-buying-help/#findComment-3283881
Interesting... I kind of had that hunch, Thank you. What settings do you play your games on? What kind of benchmarks are you getting? I just want to know from a user vs. any old website... lol. Are you happy with it?
https://linustechtips.com/topic/239474-gtx-980-buying-help/#findComment-3283976
Thank you for the input! The higher price must be demand then? Im confused as to why the price would be more expensive if the performance is  less....
https://linustechtips.com/topic/239474-gtx-980-buying-help/#findComment-3284005
