is this enough power
Go to solution Solved by Aniallation,
The CS is nothing mind blowing for the price.
http://www.hardocp.com/article/2014/01/15/corsair_cs550m_550w_power_supply_review/9#.VE0y3_nF-So
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=366
If you're not planning to SLI, I would suggest one of these PSUs.
http://uk.pcpartpicker.com/part/xfx-power-supply-p1550bbefx
http://uk.pcpartpicker.com/part/seasonic-power-supply-s12g550
http://uk.pcpartpicker.com/part/super-flower-power-supply-sf550p14xehx
@AlwaysFSX please do some research rather then slapping down an answer to be the first one to the thread. There is a difference between a 500W EVGA 80+ and a 500W Seasonic.
PCPartPicker part list: http://uk.pcpartpicker.com/p/VQWcyc
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£174.50 @ Ebuyer)
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard  (£94.99 @ Amazon UK)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  (£62.39 @ Aria PC)
Video Card: EVGA GeForce GTX 970 4GB ACX Video Card  (£262.99 @ Ebuyer)
Case: Corsair 450D ATX Mid Tower Case  (£90.00 @ Aria PC)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  (£29.99 @ Amazon UK)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  (£69.29 @ Aria PC)
Total: £784.15
Generated by PCPartPicker 2014-10-26 17:29 GMT+0000
i'm planing to OC CPU and GPU in the future and get a corsair 100i  (this is for gaming Gaming)
https://linustechtips.com/topic/239405-is-this-enough-power/
http://linustechtips.com/main/topic/199255-how-many-watts-do-i-need-check-here/
NOT on that power supply! The standard 80 Plus EVGA 500W is a horrible PSU, please don't get it and overclock a 4690K and a 970 off of it. Poor build quality and voltage regulation and ripple are also bad. At least the 80 Bronze version should be run at stock, but you should be considering a power supply from a reputable OEM if you're looking to run your system overclocked. Spend a bit more and get a proper power supply.
"Rawr XD"
https://linustechtips.com/topic/239405-is-this-enough-power/#findComment-3282875
NOT on that power supply. The standard 80 Plus EVGA 500W is a horrible PSU, please don't get it and overclock a 4690K and a 970 off of it. Poor build quality and voltage regulation and ripple are also bad, you should be considering at least the 80+ Bronze version. Spend a bit more and get a proper power supply.
http://uk.pcpartpicker.com/part/corsair-power-supply-cs550m
https://linustechtips.com/topic/239405-is-this-enough-power/#findComment-3282905
There's nothing wrong with it. It's a good budget PSU: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=384
Simple Stryker (Now Finished  ;) )
The Terrible HP
https://linustechtips.com/topic/239405-is-this-enough-power/#findComment-3282933
"Rawr XD"
https://linustechtips.com/topic/239405-is-this-enough-power/#findComment-3282945
Liked, Seasonic are the best, evga is shit and alwaysfsx doesn't know whats he's talking about
https://linustechtips.com/topic/239405-is-this-enough-power/#findComment-3282968
It's a noticeable quality decrease compared to even the 500B, and I wouldn't even recommend the 500B for an overclocked 4690K as well as an overclocked 970.
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story4&reid=384
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story5&reid=384
HEC made, less heatsinks on parts then there should be, all Teapo secondaries... *shudder*
"Rawr XD"
https://linustechtips.com/topic/239405-is-this-enough-power/#findComment-3282970
I think you're being far too harsh on a PSU that is so cheap. Of course the ripple isn't going to be among the best and nor are some of the components. I think it's a decent PSU for the price, especially when it's compared to some of the other crap at that price that explode after 5 minutes.
The Terrible HP
https://linustechtips.com/topic/239405-is-this-enough-power/#findComment-3283006
I wouldn't mind using it for a cheaper build, but considering the OP's components and intentions then it's definitely a no from me.
"Rawr XD"
https://linustechtips.com/topic/239405-is-this-enough-power/#findComment-3283039
The system draws about 300W under load, doesn't matter what power supply you get, so long as it's good (which this one is) then you're not going to have a problem.
Excuse me?
https://linustechtips.com/topic/239405-is-this-enough-power/#findComment-3283078
The class of the power supply and what the internal components were designed for definitely isn't appropriate for this situation.
"Rawr XD"
https://linustechtips.com/topic/239405-is-this-enough-power/#findComment-3283097
It's not the best, no, but it works for the situation and you can draw a good amount of wattage from it since the system doesn't draw that much to begin with.
https://linustechtips.com/topic/239405-is-this-enough-power/#findComment-3283111
Considering OP is spending almost £800 on a PC, it's still a better idea to get something of higher quality.
"Rawr XD"
https://linustechtips.com/topic/239405-is-this-enough-power/#findComment-3283134
Total: £784.15
Overclockers UK:
YOUR BASKET
Total : £169.58 (includes shipping : £8.00).
Then use code 'SFCASE' to get free shipping
http://forums.overclockers.co.uk/showthread.php?p=27058117
The Superflower Leadex is a very good psu and is currently on offer. It is basically the same as the EVGA Supernova G2 which shares the same platform/oem)
https://linustechtips.com/topic/239405-is-this-enough-power/#findComment-3289431
