Sooooo my rig has collecting dust for a few months and now I want to do some cleaning works, I'll clean both exterior and interior (including filters and fans and GPU fan), but I got some question
1. What kind of cloth should I use to clean?
2. As long as I shut the PSU down, I can clean the components with wet cloth with no issue right?
3. My GPU doesn't have a backplate and I want to clean it, are there issues with touching a GPU w/o backplate?
4. Do I have to unplug all cable even with PSU down? Because if I have to it's gonna be a pain in the ass to replug them
Appreciate all answers here, thanks :)
Scarlet KnightIntel Core i3 6100 || Antec A40 Pro CPU Cooler || MSI Z170A Gaming M5 || Kingston HyperX 16GB DDR4-2133MHz || Samsung 850 Evo 120GB || Seagate Barracuda 1TB || Gigabyte G1 Gaming R9 390X 8GB || Seasonic M12II 620W || In Win 503 || Corsair Strafe || Steelseries Kinzu V3 MSI Edition || Dell UltraSharp U2414H || Xiaomi Alumunium Mouse Pad (S)
#Gadget:
Phone: BlackBerry Classic Q20, Samsung Galaxy Note 4 S-LTE SM-N916S
Console: PlayStation 4 500GB CUH-1206A
Tablet: iPad Air 2 16GB Wi-fi Only
Laptop: MSI GE62 (i7 4720HQ || 8GB DDR3 || NVIDIA GTX960M || Samsung 650 EVO 120GB + 1TB HDD)
In-ear Monitor: Xiaomi Piston 3.0
https://linustechtips.com/topic/239362-cleaning-rig-for-the-first-time/
I cleaned my pc today, unplug everything. And just clean and try not to touch the pc with fingers and make sure they are staticly uncharged
By touching the case you can be staticly uncharged right?
#Gadget:
1. compressed air
2. no water nope nope, well you can but it will need to be 100% dry and as the water evaporates it leaves residue then can degrade the circuits. I wouldn't
3. power off none at all just dont bend anything
4. master switch on back of PSU and then remove the kettle lead
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
None of this is needed. Just unplug it, bring it outside, and use compressed air to blow out as much dust as you can. It doesn't have to be perfectly clean.
"Rawr XD"
Compressed Air and done. For the GPU backplate and the PSU I use a microfiber cloth.
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
Thanks guys, but compressed air is not available where I live, so I am going to use a new, clean paint brush instead, it's gonna take times but will it work?
#Gadget:
it should, just be careful (duh) :)
Recovering Apple addict
ASUS Zephyrus G14 2022
CPU: AMD Ryzen 9 6900HS GPU: AMD r680M / RX 6700S RAM: 16GB DDR5
