Need a new PSU! Please Help
Solved by ShabbirKAN,
If you don't plan on adding second one, get the Seasonic 550RM, else get the Evga 750W G2.
PLEASE DO NOT GET CORSAIR RM
AX series is fine
If you don't plan to add a second 780, then a 550W Rosewill Capstone or Seasonic G will be perfect.
Corsair RM Series are all Gold Rated
Corsair AX Series are all Platinum Rated
They both have 5 year warranties and a very speedy RMA with Corsair. I'd recommend about 600-700w for your computer, so that you have headway for overclocking and an extra card later
Use something like Coolermaster's PSU Calculator.
THANK YOU EVERYONE!! the Seasonic G-650 was on sale so i just grabbed that thank you for your advice!
