Not really. Unless you lower a fair number of settings.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/239019-surround-help/#findComment-3277937
on medium-low settings yeah
why are you doing surround 1440p?
you obviously cant afford the 3 980s needed to run it at 60fps high settings.
https://linustechtips.com/topic/239019-surround-help/#findComment-3277948
Bigdaddy, what sort of fps/settings are you using on the 3 980s on 3x 1440p monitors?
I haven't even enabled surround since I upgraded. Been just gaming on one. I have a 4k screen on the way to replace my middle so it won't even be an option in a couple of days.
https://linustechtips.com/topic/239019-surround-help/#findComment-3302663
