Hey, would a GTX 670 be able to support running this monitor at 4k? Thanks
http://www.amazon.com/Seiki-SE39UY04-39-Inch-Ultra-Discontinued/dp/B00DOPGO2G/ref=cm_cd_ql_qh_dp_t
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/238574-gtx-670-help/
Technically it can but expect lousy performance
Scarlet KnightIntel Core i3 6100 || Antec A40 Pro CPU Cooler || MSI Z170A Gaming M5 || Kingston HyperX 16GB DDR4-2133MHz || Samsung 850 Evo 120GB || Seagate Barracuda 1TB || Gigabyte G1 Gaming R9 390X 8GB || Seasonic M12II 620W || In Win 503 || Corsair Strafe || Steelseries Kinzu V3 MSI Edition || Dell UltraSharp U2414H || Xiaomi Alumunium Mouse Pad (S)
#Gadget:
Phone: BlackBerry Classic Q20, Samsung Galaxy Note 4 S-LTE SM-N916S
Console: PlayStation 4 500GB CUH-1206A
Tablet: iPad Air 2 16GB Wi-fi Only
Laptop: MSI GE62 (i7 4720HQ || 8GB DDR3 || NVIDIA GTX960M || Samsung 650 EVO 120GB + 1TB HDD)
In-ear Monitor: Xiaomi Piston 3.0
https://linustechtips.com/topic/238574-gtx-670-help/#findComment-3272837
No
A 670 is far from the ideal 4k graphics card.
https://linustechtips.com/topic/238574-gtx-670-help/#findComment-3272839
No
I have two in sli, and I don't play intensive games lol
https://linustechtips.com/topic/238574-gtx-670-help/#findComment-3272855
A gtx 670 would run the 4k monitor. But you wouldn't be able to do much more than watch a youtube video in 4k.
Gaming rig- Cpu- Amd 9590, 16gbs of G Skill Ram, Gpu- GTX 760 windforce 3 edition 2gb. A Thermaltake water 2.0 water cooler for my cpu. Keyboard- Thermaltake Posieden , Case- 750D, Mobo Asus 990fx R2.0. 24 inch Dell LED monitor
https://linustechtips.com/topic/238574-gtx-670-help/#findComment-3272858
I have two in sli, and I don't play intensive games lolB
SLI should suffice then.
https://linustechtips.com/topic/238574-gtx-670-help/#findComment-3272860
I wouldn't try to run a 4k monitor with a 670.  That being said I also would not buy that monitor.  Get a nice 27 in 1440p monitor instead.  Or one of the LG ultra wides.
01010010 01101111 01100010  01001101 01100001 01100011 01010010 01100001 01100101
https://linustechtips.com/topic/238574-gtx-670-help/#findComment-3272864
If you have two of them don't ask if "A 670" can run it.  "A 679" implies one card not two.
https://linustechtips.com/topic/238574-gtx-670-help/#findComment-3272865
I know, I meant in terms of the actual card supporting the resolution. Some cards don't support 4k ;o
https://linustechtips.com/topic/238574-gtx-670-help/#findComment-3272876
A 670 will run 4k resolution no prob.
Hopefully this chart gives you a idea on 4k perf
Like watching Anime? Consider joining the unofficial LTT Anime Club Heaven Society~ ^.^
https://linustechtips.com/topic/238574-gtx-670-help/#findComment-3272894
pls, I only play minectaft & league of legends and two 670s is almost up to par with a 690 lol
https://linustechtips.com/topic/238574-gtx-670-help/#findComment-3272912
Am I the only one in the world who thinks 4K is overrated? AMD/Nvidia want to push out 8K when 4K is nearly impossible... pfft.
You can get 300fps+ at 1080p on LOL. 4k wouldn't be a problem. Just don't expect to get much out of high end games.
Main: i7 2600 | ASUS P8Z68-V | 2x4GB Vengeance 1600 | GTX 580 | WD Blue 1TB | Antec TP-650C | NH U12S | W7 x64
Backup: X6 1090T | MSI K9A2 Platinum | 4x2GB XMS2 800 | GTX 550Ti | WD Blue 1TB |  Antec VP-450 | CM TX3 | W7 x64
https://linustechtips.com/topic/238574-gtx-670-help/#findComment-3272915
you can get 300fps+ at 1080p on LOL. 4k wouldn't be a problem.
ya, but idk this monitor is funky lol. it only has hdmi, but you have to use their "special" hdmi 4k cable but idk if the 670 does 4k through hdmi
https://linustechtips.com/topic/238574-gtx-670-help/#findComment-3272922
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=4k%20hdmi
HDMI 1.4 only supports 30hz.. I think you're screwed, lol I'd suggest finding a compatible monitor with DP.
https://linustechtips.com/topic/238574-gtx-670-help/#findComment-3272961
It's entirely possible that your 670's won't do 4k over hdmi. I'm not 100% on hdmi spec but it's 4k @24 fps on the newer version. It's possible that the hdmi spec of your cards doesn't support 4k.
My opinion on the monitor stands. Get a nice 27 1440p instead.
https://linustechtips.com/topic/238574-gtx-670-help/#findComment-3272970
ya the tv is loopy, it says it can only go to 30hz too
https://linustechtips.com/topic/238574-gtx-670-help/#findComment-3272972
Is the perfect pixel thing any good? like QNIX or something
http://www.amazon.com/QNIX-QX2710-Evolution-2560x1440-Perfect/dp/B00CAKD6LI/ref=sr_1_1?ie=UTF8&qid=1414216044&sr=8-1&keywords=QNIX+QX2710
https://linustechtips.com/topic/238574-gtx-670-help/#findComment-3272973
https://linustechtips.com/topic/238574-gtx-670-help/#findComment-3272990
Too thick, thick bezel's make me want to vomit. They're not cheap..
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236294R&cm_re=asus_2560x1440-_-24-236-294R-_-Product
It's needs to be amazon, half of the money I have is birthday giftcards lol. Max budget is eh 360-390
https://linustechtips.com/topic/238574-gtx-670-help/#findComment-3273009
https://linustechtips.com/topic/238574-gtx-670-help/#findComment-3273053
