Noob question about 3pin fans.
Solved by LogicalDrm,
Understood. So to sum up I would have to go to BIOS and manually change the voltage and lower it so it would lessen the noise right?
Yeah. That would be the easiest way. Other is to use Asus software which does the same thing. Difference is that software has to be loaded with windows to work so fans will be at full speed at boot.
Featured Topics
SparkFox621 ·
Posted in Troubleshooting0 -
JJackson ·
Posted in Networking0 -
logan mcd ·
Posted in Graphics Cards4 -
Xtppph ·
Posted in Troubleshooting1 -
Average Nerd ·
Posted in Troubleshooting9 -
Jakubman625 ·
Posted in Troubleshooting3
