Hi Guys, i play fsx i don't usually get a constant 30 fps but i get enough to get by. Recently i have noticed my frames have dropped significantly down to 7 fps. I am not sure if it is a driver problem or what but i need help please. If anyone can help me fix the problem and even help me to get more fps generally that would be appreciated.
My Specs:
Amd A6-3670k
Amd R9 270
Gigabyte GA-A55M-DS2 Rev 3.0
2 screens Compaq 20 inch monitor 1600 * 900
Acer G125H 1280*1024
WD 500GB
Windows 7 64bit
https://linustechtips.com/topic/237971-low-fps/
check your temps see if anything is running too hot and throttling
https://linustechtips.com/topic/237971-low-fps/#findComment-3263588
what is fsx?
a flight simulator game
https://linustechtips.com/topic/237971-low-fps/#findComment-3263593
