Which way for 20 pin
Solved by Altecice,
as above the holes the pins fit into are round/square and they will only match up in the correct orientation. Its literally impossible to install it the wrong way without breaking something.
Featured Topics
PapaAquaWet ·
Posted in Graphics Cards0 -
Average Nerd ·
Posted in Build Logs0 -
4
1
5
alexfic ·
Posted in New Builds and Planning3 -
1
