I just built a new PC. I connected all the wires and stuff. I pressed power, but the monitor remained blank. The fans inside are all spinning, but the monitor continues to remain blank. I tried it again with the motherboard video outputs instead but same problem. I don't think monitor is problem, because i tried it with my TV and this old VGA monitor. Please help!
My system specs:
Case: Corsair Carbide 200R
Mobo: Asus Z97-A
CPU: Intel Core i5 4690K
RAM: Kingston HyperX Fury 8gb(2x4gb)
Power supply: Corsair CX600 80+ Bronze
GPU: XFX DD Radeon R9 270
HDD: WD Blue 1TB
PLEASE HELP!
https://linustechtips.com/topic/237714-pc-doesnt-post-after-building/
Did you plug in the power cables into the video card and are the fans spinning on it? Also, check to make sure you are on the right input on the monitor (Example: If you are using hdmi, make sure the monitor is set to hdmi)
My name is Sebastian, I relate to Linus
My system specs:
Mobo: Asus Z97-A
HDD: WD Blue 1TB
PLEASE HELP!
Is everything connected properly, what sound does the system make as it turns on? Is anything unseated (go and push everything down and make sure it's all connected).
"Use the force Harry"
                   -Gandalf
Your monitor MUST be connected to the GPU's video output.
Double check that all connections including power cables have been fully pushed in and latched. Your GPU also requires it's own power cable
Did you forget your motherboard standoffs?
have you tried thowing money at it? I heard PCs like that.
honestly, easiest way is take everything apart and put it back together again making sure all is connected properly.
or send pictures.
If you judge a fish by its ability to climb a tree, it will live its whole life thinking it's stupid.  - Albert Einstein
PC doesn't post after building.
Well it's pretty impressive that your PC can build, but you can't expect to post your letters for you. You're gonna have to do that yourself. :P JK :D
Sorry, couldn't resist the urge.
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
try different output from your gpu. if it doesen't work. try removing your gpu and using the motherboard's output. if nothing works. well idk. does the mobo makes a certain beep ? can we get pictures ?
I plugged in every power cable that is needed. Including the GPU 6-pin PCI-E one. the fans spin for a while, then stop. then start, spin for awhile, then stop. my monitor is set to hdmi.
I used HDMI and DVI. Both doesn't work. I also used the mobo's output. Didn't work
In my case, the standoffs were preinstalled. my monitor was connected to the GPU output. as i have typed, i tried it with my tv and old monitor too. doenst work.
I did both. it didnt work :( the mobo doesnt make beeps either. i will try to get pictures.
have you tried turning on your monitor ? is it pluged in ?
i disconnected everything and connected it back. didnt work. i pushed everything back down too. on mobo i connected 24 pin and 8-pin. on gpu i connected 6-pin. it's all that's needed for mobo and gpu right?
have you tried switching inputs form the monitor ?
no I ment in the monitor., you know when you switch with the buttons on the side /back ot botom ?
you should try clearing your bios if its not posting it could be something is stopping the bios.
Please Quote so i know you have replied. | If we have provided a solution to your problem mark it with answer found.
And also please read the COC and avoid the embarrassment and lecture that will ensue.
