Anyone knows anything about this Cables?
http://www.digikey.com/product-detail/en/8KC3-0726-0500/3M12026-ND/3641403
Need one, or something similar for my GPU, the local store only has a 7 cm one and that sure as hell is to short. and no its NOT for mining.
its for a upcoming rig and i don't want my Card to sit on the motherboard.
https://linustechtips.com/topic/237083-3m-riser-cable/
As long as your GPU has external power you will be fine. Usually these risers cant carry enough power for cards that rely on power from your motherboard, but they work fine with external power(6/8 pin PCI-etc.).
https://linustechtips.com/topic/237083-3m-riser-cable/#findComment-3250820
Hmmm are you talking about psu cables now?
https://linustechtips.com/topic/237083-3m-riser-cable/#findComment-3250827
Well, you will need external power for your graphics card. The riser I will provide below can only handle 15 watts, which will fry unless if your graphics card has external power(like a GTX 980 for example). That riser is a bit weak sauce, but they typically can only handle 45 watts, which is why you will want to use a graphics card that gets its power from another source(like the 6/8 pin).
http://www.logicsupply.eu/riser-cards/pci-express/pelx16-c10/
https://linustechtips.com/topic/237083-3m-riser-cable/#findComment-3250856
well my card has 3x 8 Pin so....yeah.
Also that riser is too short :P i´d need to Daisy chain 3 of those. and for that price i might just go a for the 3M riser, thanks anyway.
https://linustechtips.com/topic/237083-3m-riser-cable/#findComment-3250873
Okay, so that won't be a problem then. Yeah, I only provided that as an example since they actually list the power limit(and I have first hand experience with frying PCI-e risers, so I just want to help prevent more of those mistakes lol).
I'll do some looking, but most of the risers that system builders use are custom built(from companies like Foxconn) and are ordered in large batches, so finding one will be fun. :)
Edit: How long do you need it to be btw?
https://linustechtips.com/topic/237083-3m-riser-cable/#findComment-3250894
to be safe i´d say around 500 mm, then i dont have to worry about length or damage it when i bend it.
Found this guy who is using TWO! 3M risers btw..
http://www.overclock.net/t/1424387/gallery-build-log-ultimate-wall-mount-rig-maxxplanck-v2-completed
BUT ill wait and keep the 3m Riser as a last resort....that price tag >_<
https://linustechtips.com/topic/237083-3m-riser-cable/#findComment-3250915
that is crazy money.
https://linustechtips.com/topic/237083-3m-riser-cable/#findComment-3250927
So I found this thread, It might give you more ideas: http://www.overclock.net/t/1427731/pci-express-extender-cables-benchmarked
I found those risers on Ali, but you would have to order 100 of each so that's less than ideal(lol).
https://linustechtips.com/topic/237083-3m-riser-cable/#findComment-3251008
LOL 100 !? ha yeah no thanks :P
https://linustechtips.com/topic/237083-3m-riser-cable/#findComment-3251020
yeah money would be a bit tight if you bought an ares III
Desktop -  i5 4670k, GTX 770, Maximums VI Hero, 2X Kingston Hyper X 3k in raid zero.
Laptop - Lenovo X230 Intel 535 480GB, 16GB Gskill memory, Classic Keyboard Mod, Triple USB 3.0 Express Card.
https://linustechtips.com/topic/237083-3m-riser-cable/#findComment-3251114
