AIO - Fans set to intake or exhaust?
Solved by Enderman,
Traditionally, front and bottom of the case is intake, and top+rear exhaust.
People who put an AiO on top will have it as exhaust. You can use an AiO as intake or exhaust, but having it as an intake at the front would give lower CPU temps.
Make sure you filter the intakes too, and avoid putting intakes at the top of a case because heat rises, dust falls, and top intakes are not usually filtered.
Featured Topics
Hichem922 ·
Posted in Troubleshooting1 -
GanjajoggiBig ·
2
220VoltsallCore ·
Posted in Storage Devices6 -
_t8r_ ·
Posted in Power Supplies3 -
