First Ever Computer Build - Need Advice
Solved by Guest,
Ok thanks I'll take these RAM, just a maybe dumb question how do you know that the Noctua D15 is going to be over the RAM slots and is not going to stop before it ??
The D15 will cover some of the ram slots. You could probably leave the front fan off but I don't know how much performance you would lose. Or if you have room in your case, you might be able to put the fan on the rear as in the picture below.
This is on a Z77 Sabertooth motherboard:
http://www.guru3d.com/articles-pages/noctua-nh-d15-review,6.html
Different board (MSI Z87)
http://www.techpowerup.com/reviews/Noctua/NH-D15/images/install8.jpg
http://www.techpowerup.com/reviews/Noctua/NH-D15/images/install6.jpg
