I recently bought some corsair vengeance 2x4Gb for my build, I placed them in correctly and Im using the ASUS sabertooth 990FX r2.0, when I turn it on I hear 1 long beep and 2 short beeps, I don't have a clue what this means and how to fix if you have any knowledge please let me know.
https://linustechtips.com/topic/233126-help-with-ram/
Did you replace old ram, or is it a new build?
Try just one of the two sticks, if that doesnt work then try the other stick. It sounds like you may have gotten a  bad module.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/233126-help-with-ram/#findComment-3185803
From ASUS' site:
A  Clean the Golden Finger of memory
B  Clean the memory slots
C  Leave only one memory stick to test
D  If convenient, please change different memory to test again
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/233126-help-with-ram/#findComment-3185842
I have tried with one stick only, but didn't try the other stick 8-}, also did I mention it constantly repeats and there's a memOK button and the light stays a light.
https://linustechtips.com/topic/233126-help-with-ram/#findComment-3185878
Do you have any other RAM you can test to make sure it's not the motherboard?
PC Specs:
CPU: i7-9700k  | Motherboard: Gigabyte Z390 Aorus Elite | RAM: 16GB's Team T-Force Vulcan 3000MHz | GPU: Zotac GTX 1070 8GB AMP! Edition  | Storage: 500GB WD Caviar Blue | 1TB WD Caviar Black | Crucial BX200 240GB SSD | OS: Windows 10 64-bit  | PSU: EVGA SuperNOVA G2 650W 80+ Gold | CPU Cooler: Noctua NH-D14 | Mouse: Logitech G502 Proteus Spectrum Headphones: Sennheiser HD 598 Special Edition's, HD 598 Cs | Keyboard: CM Storm QuickFire XT MX Blues Monitors: Acer GN246HL 144Hz, Acer G226HQLBbd 60Hz | Case: Phanteks Enthoo Pro.
https://linustechtips.com/topic/233126-help-with-ram/#findComment-3188968
