It will work, the 4th pin will simply not be connected to the fan controller. Don't waste money buying a PWM specific model btw if you are using a fan controller for them
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/232821-4pin-to-3pin/#findComment-3182150
You'll not be able to control their lower end rpm speed (they will not spin until they reach a certain % load) with simple voltage regulation (the third pin on the connector), but no big deal. :)
CPU: INTEL i7-4770K | CPU Cooler: Noctua NH-C12P w/ NF-A15 | MoBo: Asus Z87-Deluxe | RAM: Corsair Vengeance Pro 8GB (2x4GB) @2400MHz | GPU: Asus GTX 760 DirectCU II | PSU: Seasonic X-850 (KM3)
CASE: Phanteks Enthoo Pro w/ white LEDs | SSD: Samsung 840 EVO 250GB (Boot Drive) | HDD: Seagate Barracuda 2TB (Storage) | ODD(s): LG BH10 BD Rewriter + LG DVD Rewriter | 5.25": Scythe Kama Panel 3.1 |
GAMEPAD: XBOX 360 | KEYBOARD: CM Storm Quick Fire Rapid-i | OS: Windows 8.1 64 bit | MONITOR: Samsung SyncMaster T220HD | SPEAKERS: Logitech LS21
https://linustechtips.com/topic/232821-4pin-to-3pin/#findComment-3182446
Umm... yeah... why not read the whole post before replying? This is about connecting 4pin fans to 3pin fan controller. Controller will be able to lower speeds to what ever is min volts that fans will use.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/232821-4pin-to-3pin/#findComment-3188160
I read the whole post and this is what I answered, in other words: It is perfectly fine, the only downside is that you'll not be able to control the fans rpm speed as fully as with using that 4pin fan on a PWM fan header.
No offence, but we're all here to help each other, let's not make pointless discussions please.
Also, english is not my native language so sometimes I phrase things the way I think is right and not the way someone whose native language is english would.
"what ever is the min volts that fans will use" will make those fans spin faster than if they were connected to a PWM fan header, which is kind of like wasting the PWM feature.
https://linustechtips.com/topic/232821-4pin-to-3pin/#findComment-3188983
The forth pin (which you'll be missing) is the PWM controller. It let's you control the fan RPM further more than only a DC fan (3-pin).
With 3-pins, you'll still be able to control the fan's RPM but it'll not be as accurate and efficient as PWM/4-pin. Google helps as well, but here's a good post and also here.
CPU: Intel Core i7-4790k | CPU Cooler: Noctua NH-D15 | Motherboard: ASUS Sabertooth Z97 MARK 1 | Memory: Kingston HyperX FURY 16GB 1866MHz | GPU: Gigabyte GeForce GTX 770 4GB Windforce
Storage: Samsung 840 EVO | PSU: CM Silent Pro 720W | Case: Phanteks Enthoo Luxe | Headset: Corsair Vengeance 2100 | Keyboard: Logitech G710+ | Mouse: Razer DeathAdder Chroma
"You see, one can only be angry with those he respects." - R. Nixon
https://linustechtips.com/topic/232821-4pin-to-3pin/#findComment-3189027
