Corsair H110 AIO
Go to solution Solved by Enderman,
yes it fits 2011-3
Helo guys im going to use a i7-5930k and i wanted to ask if the Corsair H110 AIO fits or do i need anything extra?
yes it fits 2011-3
yes anything that fits 2011 fits 2011-3 they use the same mounting points
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
Yes, it will fit nicely. 2011 and 2011-3 use the exact same mounting holes and hardware.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
Thank you all 3. Would like to mark you all 3 as solved but only can do it on one guy D:
