Best cooling
Go to solution Solved by loccilucas,
Have some fans pulling air into the case from the front. And have some fans exhausting air out the top, it's best to have more fans blowing air INTO the case than out.
As for the fans, the side of the fan that has the 'X' going across it (the frame that's holding the blades) is the side the air comes out.
What is the best cooling way for my pc what way do I put the fan
How do I find the way a fan spins and pulls
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
https://linustechtips.com/topic/232095-best-cooling/
The side with the blades and hub is the side that pulls the air through.
https://linustechtips.com/topic/232095-best-cooling/#findComment-3172820
In my opinion, having the intake at the front and/or bottom of the case, and the exhaust to the back and top is the best. I'm not sure if all fans have this, but the Corsair SP and AF fans have arrows which point which way the fan spins and the direction of airflow
CPU: AMD Ryzen 7 3800X GPU: ASUS Strix Radeon R7 5700 XT OC Edition Motherboard: ASUS Crosshair VIII Hero RAM: G.Skill Trident Z DDR4-3200 CL14 SSD: 2x Samsung 970 EVO Plus 1TB PSU: Corsair AX860 Cooling: NZXT Kraken X72 Case: Corsair Crystal Series 570X Mirror Black Display: BenQ XL2420Z  Keyboard: Corsair K95 RGB Cherry MX Blue Mouse: Logitech G502 Proteus Spectrum Audio: Logitech G633 Artemis Spectrum
https://linustechtips.com/topic/232095-best-cooling/#findComment-3172841
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/232095-best-cooling/#findComment-3174915
