I recently got a H100 for my computer, and I have it all set up and running well.
Except for the fans revving up occasionally for about 5 seconds.
While the computer is idle, roughly every minute, the fans that are plugged into the H100 fan controller rev up to ~80% speed for five seconds, then drop back to ~20%. CPU temperature is around 30c. The fan controller is set to the slow speed profile.
Any ideas?
[TRUENO] i7 4770k (~4.4Ghz, 1.28v) || Thermalright Macho 120 || Asus Z87 Gryphon || 2x8Gb Mushkin Blackline|| Reference NVIDIA GTX770 || Corsair Neutron GTX 480GB || 2x3TB WD HDD || Corsair 350D || Corsair RM750
https://linustechtips.com/topic/231706-corsair-h100-issues/
Sounds like a fan issue more than a rad issue, have you tried other fans?
Edit: try removing the fan controller and plugging straight into the mobo
1. Other fans work the same. I tried some XIgmatek ones and they did the same thing.
2. Motherboard only has 4 pin fan connectors, when I plug into those, the fans run at 100% speed.
https://linustechtips.com/topic/231706-corsair-h100-issues/#findComment-3167936
Isn't there some settings in the bios to adjust speed settings of the fans, if it's 4 pin it should be able to be voltage controlled
https://linustechtips.com/topic/231706-corsair-h100-issues/#findComment-3167941
The fan control on the BIOS is... tricky. No, non PWM fans just stay at 100% speed. No voltage control.
https://linustechtips.com/topic/231706-corsair-h100-issues/#findComment-3167950
Guys, I really could use some suggestions. Should I contact Corsair?
https://linustechtips.com/topic/231706-corsair-h100-issues/#findComment-3182106
Don't use Corsair Link, control everything through your motherboard.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/231706-corsair-h100-issues/#findComment-3182668
Corsair link is not connected.
https://linustechtips.com/topic/231706-corsair-h100-issues/#findComment-3184641
