nzxt phantom 240 and a H105 liquid cooler?
wildgg
so for my new build i'm getting the nzxt phantom 240 case and i wanna know if the Corsair H105 will fit in this case, the radiator is 38mm thick.
if it will not fit wich prefilled cooler would you recomment me for this case? i was looking at the H100i i can go for the H110 but i have 2 nf-f 12 noctua fans allready so it has to be a 240mm rad.
thanks in advance!
Edit: i was plannign to mount the radiator inside the case and both fans under the top plastic cover. the reason for this is i don't want to see the noctua fans.
Recent build: Fractal Design - Torrent reviewMeshify C / The 1080TI Strix Noctua modDefine S X58 Xeon build  / Specs: i7-14700KF 5.8Ghz - ASUS TUF RTX 4080 super - G.Skill Ripjaws 32GB 4000mhz CL18 -  Gigabyte Z690 Gaming X d4 - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua D15
