C++ Substring for Integers or setting max width for Integers?
Go to solution Solved by Ciccioo,
if you want to extract the last two digits of a number, you can just work on the integer using modulo
2014 % 100 = 14
this way the user can enter the year in whatever format, because
2014 % 100 = 14
14 % 100 = 14
Hi , I'm currently working on a project for my c++ course in which a user enters 3 different numbers for a date. The program then will ask them which of the following formats would they like their output.
1. 10/7/14
2. October 7, 2014
3. 7-Oct-2014
I can handle everything but the first option. If the user entered 2014 for his/her year, how would i make sure the program only displays 14 instead of 2014?
You grab the whole line, and separate each into 3 strings through substringing such that
string day = "10", month = "7" and year = "2014"
for year, simply check for size of the string.
if(year.size() == 4)
   substring one more time to extract the last 2 digits
you can then use stringstream or stoi to convert and check day/month
month first depending on year(if leap feb has 29) then day depending on month
2014 % 100 = 14
2014 % 100 = 14
14 % 100 = 14
2014 % 100 = 14
2014 % 100 = 14
14 % 100 = 14
Thank you SO MUCH. I completely forgot about that operator, and thanks for the simple solution. Much appreciated.
